Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? |
| Print at Sep 14, 2026, 2:19:13 AM | |
| Posted by Wendell_Burke at Dec 26, 2024, 10:54:50 PM |
Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? This might be a strange question so I've included an example. In the top picture is a lava lamp which I modified and got to appear just as desired. https://www.dropbox.com/scl/fi/zvrtq9ne80j2nr...&st=x6po0r5c&dl=0 In the bottom is a picture of the same lava lamp in a ‘room’ at night. The lamp is on a bookshelf and as we can see, the light is working great. It’s a bright blue light reflecting well at only 5% off the surrounding shelves. The light at its source appears bright white. Maybe it’s faintly tinted blue, but it’s mostly if not entirely white in appearance. My question: Is there a way to keep the effect of the light at it falls on its surroundings, while turning down its appearance at the source? Think of a window. When you look out a window at night, it’s dark. It’s not a patch of white. You can see everything out the window, but there’s ambient light. The ambient light comes through and illuminates a room to some degree. This is what I’m talking about. Can that be done in SW3D? If so, how? |
| Posted by GaudiGalopin3324 at Dec 27, 2024, 7:20:02 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light?Oh, the gods. That's a great million euro question. The first thing to do is forget about MTL and OBJ, and other codes, they won't help. There is no way to get reflected and scattered light in the SH3D program. But you can make a high-quality ILLUSION of such light in the room. And the whole task will be to find the proportion between the light output of the lamp and the power of the ILLUSION of diffused light. SH3D has a royal lamp for such purposes. This is "Invisible inward light half sphere". make a cap with a size of, for example, 250 X 250 X H200. Lift it off the floor level by 30 cm, cover the shelf rack and your blue lamp with such a hood. Assign a blue color to the hemisphere, too, and start with 1% power for it. Make a trial rendering of 400 pixels at the third quality level. It should take you 3-4 seconds. And now you need to find the right ratio between the power of this hemisphere, the power of your blue lamp and the brightness level in the render settings. Everything will work out! The total power of the hemisphere should be no more than 5%, otherwise it will dominate your blue lamp. You can download such a hemisphere here A better diffused light effect will be from several hemispheres in a low-power room. They will give a smoother diffused light. Or rather, his ILLUSION. |
| Posted by GaudiGalopin3324 at Dec 27, 2024, 8:47:01 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? a quick example. I applied two hemispheres with an up and down direction. You can do it in different ways. The color of the hemispheres is blue. The hemispherical capacity is 2 and 4%. The power of the blue lamp on the shelf is 70%. It's without hemispheres with hemispheres ![]() |
| Posted by Keet at Dec 27, 2024, 10:12:00 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Our resident lighting magician at work! The original LightShapes library: LightShapes.sh3f You can read more about it here (heading "More lights capabilities") and here (halfway down the page). ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Wendell_Burke at Dec 27, 2024, 7:21:08 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Thank you. <😊 And I appreciate what you’re saying about creating its illusion, as you’ll see in a few moments. I haven’t seen this library of light shapes that Keet mentions, but thanks for that Keet! I’ll definitely install that! So, GaudiGalopin3324, basically you’re saying, take or create two ½ sphere light shapes, color them the appropriate color, make them invisible? Place one on the center floor and the other on the center ceiling, do the balancing act between light sources, and it should create the illusion of ambient light in the room? That’s excellent! Great, and thank you! I do have another question though, to take my original question a bit further… Though the goal is ambient light, is it also directional at all? I’ve provided another example from my current project below. https://www.dropbox.com/scl/fi/mg8lewtbfakjb5...&st=maa8lse8&dl=0 So, I’m building a reproduction of the crew quarters from Star Trek: The Next Generation. As you can see, there are no windows, but the ILLUSION of windows. <😉 As when I tried to create them as windows, positioning them on diagonals made those annoying 90 degree corner angles appear, and I couldn’t have that. But I digress. What you see is basically the window shape used much like a canvas. I applied a starscape to it, which then distorted, but turns out I liked the effect. Anyway, to my 2ndary question: If I positioned those invisible spheres, not on the floor and ceiling, but against each window, would they create the >directional< illusion of light streaming in from these illusory windows? |
| Posted by Keet at Dec 27, 2024, 7:36:26 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? I haven’t seen this library of light shapes that Keet mentions, but thanks for that Keet! I’ll definitely install that! It's the same library as GaudiGalopin3324 already mentioned and gave a link to. I just provided the oroginal link on Sweet Home 3D.As you can see, there are no windows, but the ILLUSION of windows. <😉 As when I tried to create them as windows, positioning them on diagonals made those annoying 90 degree corner angles appear, and I couldn’t have that. But I digress. You can solve that by placing the windows in a vertical wall and export both wall and windows. Then import it and tilt it to the correct position. This works assuming your windows are imported as "Door or window" so they cut a hole in the wall. You can set a d value of d 0.3 or d 0.4 for the glass material in the MTL file to make it transparent.I'll leave answering the light question to GaudiGalopin3324, he's much, much better at that than I am. I do know that if you create the windows like I mentioned that you can place a light behind them that will shine through the glass (if your glass material is transparent). ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Wendell_Burke at Dec 27, 2024, 10:01:32 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? You can solve that by placing the windows in a vertical wall and export both wall and windows. Then import it and tilt it to the correct position. This works assuming your windows are imported as "Door or window" so they cut a hole in the wall. You can set a d value of d 0.3 or d 0.4 for the glass material in the MTL file to make it transparent. I'll leave answering the light question to GaudiGalopin3324, he's much, much better at that than I am. I do know that if you create the windows like I mentioned that you can place a light behind them that will shine through the glass (if your glass material is transparent). Really? I didn't realize that would work. That's good to know. Thanks! Unfortunately I don't believe it would work here because that diagonal roof panel is also arced at 7% to accommodate the arced outer wall, and I know that any arc at all causes a problem with doors and windows. You advised me about that with an earlier question I had. I ended up rebuilding that diagonal roof several times from individually arced pieces, to now, one large arced panel, which works much better than the earlier versions did. Oh, I got that yafaray thing installed, thanks! |
| Posted by Keet at Dec 27, 2024, 10:37:49 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Really? I didn't realize that would work. That's good to know. Thanks! Unfortunately I don't believe it would work here because that diagonal roof panel is also arced at 7% to accommodate the arced outer wall, and I know that any arc at all causes a problem with doors and windows. You advised me about that with an earlier question I had. With an arced wall that wouldn't work, only with a straight wall. From your image I thought the angled roof part with the windows was straight. A 7% arc is difficult to see on a flat image. If you could keep the part with the windows straight you could still try the window-in-wall method, otherwise you're out of luck.By-the-way, that would mean that your windows also have a 7% arc? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Wendell_Burke at Dec 28, 2024, 1:23:38 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? The original LightShapes library: LightShapes.sh3f You can read more about it here (heading "More lights capabilities") and here (halfway down the page). I think I spoke too soon. I can't seem to download the file. I click on the link but nothing happens. By contrast I went looking for other links for it and found a few at a page called Sourceforge called 'Logos Lightshape' and 'Neon Light shape' and those downloaded fine. I saw the confirmation messages stating they were added to the libraries, but not for the original Lightshapes library. Here’s a pic of all of my light options currently under the search word ‘light’. Unless that library was incorporated without letting me know, but that would be a 1st so far. https://www.dropbox.com/scl/fi/am97zj7ey4ekz8...&st=3h6o2aj3&dl=0 Does that link work for you? Do you have another I might try? |
| Posted by Wendell_Burke at Dec 28, 2024, 1:49:46 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? With an arced wall that wouldn't work, only with a straight wall. From your image I thought the angled roof part with the windows was straight. A 7% arc is difficult to see on a flat image. If you could keep the part with the windows straight you could still try the window-in-wall method, otherwise you're out of luck. By-the-way, that would mean that your windows also have a 7% arc? Ok, that's what I'd figured, and, oh, no, I wouldn't imagine anyone else, looking at that pic would know the roof panel was arced. I only know because I made it and I forgot until I just went and checked. Actually, no, the windows only rotate on the one axis so they generally match the wall, but if you look closely you'll see they don't all line up perfectly. I had to push some back a tiny bit further so that they would at least touch the wall due to the arc. Some parts of them sit a little more recessed into the wall than other parts of the same 'window', but this was the best solution I had to sustain the illusion of it all being as it should be. I used to have greater gaps where the windows weren't even touching the walls, and that took me a while to discover because with the common colors, perspective and layout, it didn't show until I manipulated the pieces in certain ways. |
| Posted by Keet at Dec 28, 2024, 8:36:49 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? The link works perfectly fine for me, just try again. If it still doesn't work use the link GaudiGalopin3324 has in his first reply where he uploaded the same library to mediafire. You can remove '(1)' from the downloaded filename to get the original name. It's the same library. This is a different library from what you posted in your dropbox image. I have both imported in my Sweet Home 3D. The LightShapes.sh3f library has the half spheres used in the example from GaudiGalopin3324. About the arced roof. I would create the roof with windows in a straight wall and export it. Then use Blender to bend the whole thing in a tiny arc. I haven't done that before but I know it's possible. On the other hand, it's 7%, barely visible. I can't even see if the arc is vertical or horizontal but from your remarks I know it's an arced wall rotated sideways. Why not try it without the arc? That way you can easily use a simple wall and insert windows with transparent glass without any problems. Make the wall as high as the windows. Then add small arced walls to the top and bottom of the part with the windows to make the top and bottom of the complete roof match your current roof. Instead of ⁔ you get something like ⏠. As small as the arc is you will be hard pressed to see the difference. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by GaudiGalopin3324 at Dec 28, 2024, 11:16:06 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? round windows can be made in a curved wall. Of course, you need to trick the system a bit. I made a wall of five parts. Three with a 7-degree bend and two short straight sections. I've carefully laid out all the sections in one arc, so you need to try harder. Now you need to turn off the magnet and insert the round window into a straight section, it is important to catch the moment when the round window stands perpendicular to the wall, then this half will cut a round hole in the wall. There is a rectangular window in the middle curved wall, and again a partially round one in a straight section. It turned out like this. now you need to save this composition to OBJ and return it back as a model. Make windows invisible and export-import again. You also need to save only the wall without windows as an OBJ and return it back, it will be an addition to the wall with a window to get the desired dimensions of the room. For now, you need to put all the sections of the wall in a common composition without tilting, align everything, group it, and export it back to OBJ and return it as a model. This trick will allow you to rotate your new wall with windows and paneling along three axes. You can't spin it without this trick. A hole in the wall is better than a canvas framed with a picture of space. You can put a large box with the texture (photo) of space outside, it is important to make the box much larger than the height of the room so that from any point of the camera the image of space falls without cropping. It is very important to make the proportions of the box exactly the same as the proportions of the texture image. I highlighted the picture with an invisible panel, it needs to be rotated along the Y axis by 270, check how it shines and correctly rotate it towards space on the box. Panel power is 15%, assigned white color. The outer space is very bright and a strong powerful light from outside gets into the room. I made a mistake, I made the illumination of the cosmos panel too strong, the image of the cosmos now looks like a night city (this is not true). The real cosmos is almost black with bright stars, but the light from it is very powerful. And it comes from all sides into the room from the windows, not as from the sun above. I didn't do it very well, but I can do it right. I made the light inside the room from the windows with very flat hemispheres of blue color (blue color is very important) The power of these flat plates is 15% hemispheres. Inside the room there are 8 towers of hemispheres 240x215 with a height of 200, the color is yellow. The different color of the lighting inside the room gives a beautiful complex interior color, the window has bright blue shades, everything is mixed inside. It always looks beautiful and the main thing is that it is true. The light from the window is always cooler than the light inside the room. the picture for space is like this The space on the box method outside the windows allows you to move the box and select the desired type of space, this is better than moving fragments in each window on canvases. And it is more difficult to highlight such individual windows. Yes, hemispheres have a direction of light. The towers shine in (and then out, of course) and down-sideways. The flatter plates shine mostly downwards. So by changing the shape of the hemispheres, you can control the flow of light. Almost manage)). Of course, such hemispheres will not shine like a spotlight, the light from them still shines in different directions, not like in a laser. But it is a good tool for correctly highlighting in the right direction. ![]() |
| Posted by GaudiGalopin3324 at Dec 28, 2024, 11:27:02 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? File here |
| Posted by Wendell_Burke at Dec 29, 2024, 6:04:09 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Keet: I totally missed the 1st link Gaudi posted. I went back and have the light library now. Thanks! & GaudiGalopin3324: It’s so funny that this is your approach because this is what I did when I started this project and had a problem with the doors and those right angle cut outs on rounded edges. Here’s a pic of the blueprint view. https://www.dropbox.com/scl/fi/ksu9gdwt4ymxsh...&st=pw2ks76s&dl=0 If you look at the inside wall on the lower left side, where the door is, I ended up doing just that. I cut the wall length short, then replaced it with a shorter straight segment. I had to mess with it a bit because that doesn’t seem to work everywhere. Some places it feels like it’s harder to get the flat segment to blend in, but at the end of the arc, it seemed to work well enough. I tried to make a few shorter segments that were arced like in your current example, but the arcs on each seemed more severe maybe because they were so much shorter, even though the arc was still 7 degrees. Keet’s right that from the other view you can’t see the arc much, but it stands out to me because I’ve been working on it for so long and now I’d really like to keep learning and see if I can make what you suggest happen. What you both said about tricking the window? By attaching wall parts to the top and bottom, I didn’t know that’s how that worked! That’s interesting! Thank you for the detailed illustrations. It helps me understand much better. Your example of the room with windows in…WOW!!! That looks amazing, and just what I’m going for! I’d love to have that thickness of the hull wall visible in the window opening like that, not to mention the different views of space. I struggled with getting pictures to not distort, but I’ve always had a lot of trouble understanding how resolution and size works, no matter how many times I read articles and the like. That room looks so much more realistic than the one I’ve made and I’m not sure I can put my finger on why. I mean the way everything is rendered looks different, better. I tried to apply large photos of space to the sky and ground, but it looked terrible, repeating all over the place and just…bad. I like this idea of the box, though that’ll limit how much I can zoom into the room, won’t it? I’ve noticed the more stuff I leave laying around in my workspace, the further away I get pushed from the interior. No, that’s ok that the light won’t be a spotlight. I like how the light scatters naturally. I also just like how it looks when it gently comes in as starlight. This is going to take me a while of trying, but I’m going to get started. So…You sunk a rectangular window into a flat segment of wall. What are the semi-circle shapes on both sides? I know they complete the shape of the window, but are they just geometric shapes? |
| Posted by GaudiGalopin3324 at Dec 29, 2024, 7:55:09 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? What are the semi-circle shapes on both sides? I know they complete the shape of the window, but are they just geometric shapes? it's just a round window from the SH3D standard library. Every time I download a new version, I always get this whole set. Take a look at your Windows and Doors section. Round window. I am sure that it is possible (with difficulty, of course) to make a curved frame around this complex hole. From the walls, you need to make separate sections and combine them into a composition, then export-import as a model. You've already done a lot of complicated details, and I'm sure you can handle that.) The space on the box can be moved from different points for each render so that it is fully visible in the windows. The stars never repeat, so the changes won't be noticeable. You don't need to insert glass into the window, this complicates the model and lengthens the rendering. And the glare from inside the room is not visible. Glare appears only if it is completely night outside. And from a close angle, from a close distance by the window. |
| Posted by Wendell_Burke at Dec 30, 2024, 7:12:40 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Ok, wait a sec. I've set up my workspace, have the 3 sections of 7 degree curved wall and 2 small straight pieces of wall, have the rectangular and two half round windows...but how are you rotating them on their side at this stage to go into your wall parts horizontally? Also, I saved that spacescape picture and checked the properties. It appears to be 6006 x 3228 pixels. When I convert that to inches, it’s 62.56” x 33.625”, and when I made a wall in SW3D that size and stuck the pic on it, the pic was way smaller and replicated itself like 100 times. That wall in your image, I’m guessing it’s maybe 8’ tall and I don’t know how wide. I don’t know what I did wrong there? |
| Posted by GaudiGalopin3324 at Dec 30, 2024, 9:16:01 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Nothing needs to be rotated yet. We need to make the walls as shown in my diagram and turn off the magnet. Without a magnet, you can rotate the round window very precisely a little bit, one degree at a time. And catch this window position when the square hole changes to a normally round hole. This is one moment, but you need to let go of your finger on the mouse at this moment))). Now all these walls and windows need to be highlighted. AND SAVE IT TO OBJ. Then return it back to the program as a model. At this stage of the return, you need to use the arrows to rotate the model in space so that this group of walls and windows stands vertically. These are the arrows. It is necessary that the view from above is correct. After that, you need to make all windows, panes and handles invisible from the model. You will get a curved wall with an uneven hole. This needs to be SAVED TO OBJ again. And return it again as model 2. Now this model can be tilted along the Y axis, for example, by 340 degrees. Just like here. And just make a wall without windows to insert the necessary width sections between the windows in the room. You also need to tilt these blind areas along the Y axis by 340 degrees. And using a magnet to glue and align. It will turn out to be the entire wall in the room with windows. And with a tilt. Now about space. You need to look at the proportions of the image first. 6006 x 3228 pixels. Make a BOX (not a wall!) with proportions of 600 cm wide and 322 cm high (for example, 10 cm thick, this is not very important). In the extended version!! On the model settings page, assign a texture to the FRONT side of the box, leave the other sides as they are white with a medium gloss, they are not visible. The image is at 100% scale. Then there will be no distortion. You can now zoom in or out of this box by checking the save proportions box. Make the height, for example, 400cm (the width will increase in proportion, the image will not be distorted). |
| Posted by Wendell_Burke at Jan 3, 2025, 10:25:02 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? I am clearly not understanding something here. Your original picture has the grouping of circular, rectangular, and 1/2 round windows oriented horizontally. I've followed the instructions, turned off magnet, closed the program and restarted it, but I see no way to rotate my collection of windows horizontally before the 1st export, which I'd need to do in order to adjust the end window alignments to the flat sections of wall. What am I misunderstanding? https://www.dropbox.com/scl/fi/lr9py75ltztsbo...&st=uwsg6ed5&dl=0 |
| Posted by Keet at Jan 3, 2025, 10:52:03 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? turned off magnet, closed the program and restarted it Why? You don't have to restart when switching magnetism on or off. There's a nice button with a magnet in the toolbar.but I see no way to rotate my collection of windows horizontally before the 1st export If you look at the image from GaudiGalopin with the 5 segments you can see that the windows are horizontal. Just resize them to fit in the horizontal composition. I.e. small height, wide width for the rectangular window. The "Fixed window" is a nice window to do that. The windows are only there to create the hole so what they look like doesn't matter. Set the width and height of the round windows to the same value as the height of the rectangular window. After placing the windows you export the walls. And after import of the walls you can tilt the walls to the correct position. You don't tilt/rotate the windows, only the walls after expor/import. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by GaudiGalopin3324 at Jan 4, 2025, 12:09:02 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? it seems to me that you need to master the basic export and import skills here. First, export to OBJ. This is done with these buttons. Select everything you need to export and click on "Export in OBJ format" in the "3D View" column at the bottom. Then do the "furniture import" and drag the OBJ file from the downloads to the import window. And there, rotate the model vertically using the arrows (as in the picture above). You don't need to turn anything off! ![]() |
| Posted by GaudiGalopin3324 at Jan 4, 2025, 12:18:16 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? The 340 Y-axis rotation should be done after the second furniture import, when the windows will be invisible and only the wall with the hole will remain (a model of a wall with a hole, without windows). You need to turn these buttons. ![]() |
| Posted by Wendell_Burke at Jan 9, 2025, 7:27:18 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? I took a little time to experiment with everything you two have shared. I got the window trick to work, though I only exported and imported once each and they don't have the actual windows in the wall piece, which I thought was the goal. It seemed to be all i needed, unless there were specific reasons for the extra exporting and importing? Once was enough to rotate it on all 3 axis. The scale was a little odd, but I just guessed and made it close enough. I did the thing where I made the whole diagonal ceiling with all the windows in it, put them together, but if I export them together, then import them back, I'm still going to see those fine lines where each segment touches, right? I've aligned them all pretty much dead on. I think it's just a thing that the program does, leaving these trace connection lines. I assume I'll just have to live with those. The light manipulation, I'm just getting started with. I was experimenting and used a small sphere outside the window but it was super blown out bright even though I set it for only 15%. I've still got a lot of experimenting with those, though. I definitely don't understand the light very well, but I'll keep working at it. I took out the overhead lights in the room but when I take pics of the room, the light always seems pretty uneven and flat, but like I said, I'm just getting started with trying to set it up the way you mention. |
| Posted by GaudiGalopin3324 at Jan 9, 2025, 7:44:13 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Great. Try to open my file, all the different light sources are placed there and you can analyze them by shape, size, power, color. Your own experiments are very good, but it may take too much time. Use my ready-made solutions. They work for sure. In such work, you need to do a lot of trial renderings in poor quality of 400 pixels in order to find the proportion of the brightness of the render and the power of the light sources. File |
| Posted by Wendell_Burke at Apr 17, 2025, 6:55:18 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Great. Try to open my file, all the different light sources are placed there and you can analyze them by shape, size, power, color. Your own experiments are very good, but it may take too much time. Use my ready-made solutions. They work for sure. In such work, you need to do a lot of trial renderings in poor quality of 400 pixels in order to find the proportion of the brightness of the render and the power of the light sources. File Hey, it's been a while but I wanted to spend some time monkeying around with the light sources. I did get those lights and thank you for that. They gave me much more leeway, though I have really been struggling with it. I thought I was doing what was suggested but in my room, I'm not getting the color effects that I was hoping for. I wanted to get that nice blue cold light coming in from the window and a warmer light inside the room that made the walls warmer and closer to matching the color from the show. I've changed things up quite a bit, but I haven't even gotten changes that I can recognize, really. I was hoping you guys could take a look at my file and let me know what I'm doing wrong with it? https://www.dropbox.com/scl/fi/8tyktt4ljrw46a...&st=22n7kbfm&dl=0 |
| Posted by GaudiGalopin3324 at Apr 19, 2025, 10:15:57 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Hi, I am very pleased with your experiment and I am ready to tell you everything I know about this issue. There are several important points. 1. The SH3D program has a limitation on the processing capabilities of large files. There are probably specific numbers, but in your case, I had to delete several large groups of models in turn. Otherwise, I couldn't start rendering, SH3D was putting a red cross. 2. You need to decide if the sun will be involved in your scene. The sun is the simplest light source, but it is difficult to connect it with the indoor light. I advise you to set the night mode to 0 hours so that the sun does not participate at all. 3. Hemispheres are a directional light source, they are a spotlight. The lower the height of the hemisphere, the flatter it is, the brighter and more directional the beam of light from this "dish". If the height of the hemisphere is high and it turns into a cocoon or tower, then the light begins to spread in all directions, not just down. Any hemisphere shines slightly outward, even a very flat one. But the main stream of light goes towards the round base, from the top. At first, all the hemispheres were wrong, they were shining in the other direction. It is necessary to determine where the rays of light are going. In our case, it's from the street inside the room and mostly from top to bottom. I've turned over your hemispheres. He directed the beams towards the room, assigned a Y-axis rotation of 50, power of 30%, color light blue, not blue. The inner hemispheres were lifted off the floor by 20 cm. their color is orange, not yellow. The power is 2%. A very important hemisphere is located at the table. It should illuminate the dark black places at the back, where the light from the street does not penetrate at all. This hemisphere mimics the reflexes in the room, which are always present in reality, but cannot appear in SH3D. Therefore, you definitely need to do this imitation yourself. 2000 width rendering mode, 3D view. The fourth highest quality mode. The rendering time is 50 minutes-1 hour and 20 minutes. I tried adding your other models, but the program refused. Therefore, what is in the frame now is the maximum. You need to understand this limit and try not to exceed it when rendering. You can remove unnecessary models, try not to assign textures, and change them to color. It helps. I advise you to avoid very black color and very black texture. Such shapes are poorly perceived during rendering. It is better to assign a dark (not black) texture. And the same goes for very white colors, preferably a little gray. the SH3D file ![]() |
| Posted by GaudiGalopin3324 at Apr 22, 2025, 10:23:09 AM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? The space video is here in the topic))) ![]() |
Current timezone is GMT Sep 14, 2026, 2:19:13 AM |
