Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Not perpendicular triangle |
| Print at Sep 28, 2026, 12:51:04 AM | |
| Posted by MartinH81 at Feb 17, 2024, 9:55:25 AM |
Not perpendicular triangle Hi Does someone know how to create a non-perpendicular triangle in sweet home 3d? I got a triangle from a furniture lib, but it is perpendicular. Bestregards Martin |
| Posted by Keet at Feb 17, 2024, 10:10:27 AM |
Re: Not perpendicular triangle You can rotate the triangle along the X and Y axes. If you need to rotate both X and Y, first set the X, export/import, and then you can set the Y. Of course you can also use the Generate 3D Shape tool under the Tools menu to generate any shape with 8 or less points. (That's the ShapeGenerator plugin if you haven't installed that yet.) ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Feb 17, 2024, 10:18:28 AM |
Re: Not perpendicular triangle You can also create a triangle room at a higher level, export it at OBJ format and import it as a piece of furniture. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 12:51:04 AM |
