Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Windows 11 - not possible to save/save-as !!!!! |
| Print at Aug 21, 2026, 9:09:44 AM | |
| Posted by Devm at Jan 18, 2024, 4:45:15 AM |
Windows 11 - not possible to save/save-as !!!!! I installed 7.2 it would't save or save as any new project,Java was smoothly. And i try lot of steps the same of http://www.sweethome3d.com/support/forum/viewthread_thread,11932 but finall would't save or save as.... |
| Posted by Puybaret at Jan 18, 2024, 8:52:17 AM |
Re: Windows 11 - not possible to save/save-as !!!!! What do you mean by it "wouldn’t save"? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Devm at Jan 18, 2024, 11:31:58 AM |
Re: Windows 11 - not possible to save/save-as !!!!! It not able save or save as when i want to have a new project it nothing happened as "I try to open a file ("open" dialogue) nothing happens. Same when I try to save or save-as, nothing happens. When I try to close the application it asks me if I wanted to safe the progress - when I click save nothing happens, no window pops up for me to choose the destination....." from anothers case of forum. |
| Posted by Devm at Jan 18, 2024, 11:36:33 AM |
Re: Windows 11 - not possible to save/save-as !!!!! Thanks for your support & helf...better to have any ID of online chat then easy to show what appened now. |
| Posted by Puybaret at Jan 18, 2024, 12:13:49 PM |
Re: Windows 11 - not possible to save/save-as !!!!! Maybe try to run the program as administrator. Even if it’s not the best solution, you could also start from an empty file that you would open with a double click then just choose the Save menu item. Just use the EmptyFile.sh3d attached to this post and rename it if you want. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Devm at Jan 18, 2024, 2:30:29 PM |
Re: Windows 11 - not possible to save/save-as !!!!! Yes,I do and able to save but wouldn't save as...what's happening...please help to solve it. Need to change Windows version or not? I try to run with administrator but the same...wouldn't save or save as. |
| Posted by Puybaret at Jan 18, 2024, 2:52:34 PM |
Re: Windows 11 - not possible to save/save-as !!!!! Run the program from a terminal window Only logs might help me understand what’s going on. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Devm at Jan 19, 2024, 2:59:22 AM |
Re: Windows 11 - not possible to save/save-as !!!!! I have do it but nothing happened and did't get log. |
| Posted by Devm at Jan 19, 2024, 6:24:50 AM |
Re: Windows 11 - not possible to save/save-as !!!!! Any other options to solve this problem? |
| Posted by Puybaret at Jan 22, 2024, 11:19:57 AM |
Re: Windows 11 - not possible to save/save-as !!!!! See bug #1212 ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Devm at Jan 23, 2024, 5:41:17 AM |
Re: Windows 11 - not possible to save/save-as !!!!! Hi Puybaret, Finally, i did.The way is upgrade windows to the new version. Thanks for your support. |
Current timezone is GMT Aug 21, 2026, 9:09:44 AM |
