Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising |
| Print at Sep 14, 2026, 6:46:45 AM |
| Posted by GaudiGalopin3324 at Jun 20, 2024, 1:04:43 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertisingI figured out how to insert GIFs into the SH3D program so that they look natural, so that the shapes overlap with the objects of the room. This is the same method of the invisible box, only it must be used in the video editor. First, I took a basic rendering of the room, picked up the gifs, thought about how these figures on the gifs would be located in the space of the room (which objects would overlap these figures, which would be blocked by the figures themselves). As a result, I made 4 layers. The first one is the basic render. The second one is the same render, only with the fireplace window cut out, where I placed a gif with fire. The third layer is a table, a sofa and a doorway (there will be butterflies flying in the kitchen, a couple of dancers appear from the opening, a girl is standing at the table). And the fourth layer is just the sofa. I made these changes in the photo editor, made a transparent background around the objects. Then you need to arrange these layers in the video editor in the order of overlapping. And place layers with GIFs between the layers. Creating a video clip is interesting because you can split the gif file at the moment when, for example, the hand begins to overlap the wall and at this moment part of the gif is transferred to the layer above. The image starts to overlap what it didn't overlap before. As a result, the figures become almost real in space, although they are not in the scene itself. This is an attempt to depict space on a flat render. These are the layers I made: The video editor differs from the render in Yafaray in that you can make the borders not very carefully, when superimposed in the video everything will connect without traces (in Yafaray there are white contours). The main thing is to keep the exact dimensions of all layers (this is obtained automatically). And then they connect into a single whole without shifts and contours. The video is not recommended for people with a weak mind to watch, sorry. I didn't find any other more decent GIFs. https://www.mediafire.com/file/culwyodjwmh736...25BD%25D0%25B3_3.avi/file |
| Posted by VeroniQ at Jun 20, 2024, 12:32:34 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising Interesting! What kind or video editor do you use? |
| Posted by GaudiGalopin3324 at Jun 20, 2024, 12:43:47 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertisingHello VeroniQ. I use the free version of the Videopad video editor. It has very simple controls, even I understand. The only limitation is that in the free version, you can export to a video file only in AVI format. Other formats are not supported, only in the paid version. |
| Posted by GaudiGalopin3324 at Jun 26, 2024, 11:09:05 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertisingI made two masks from my render. With a hole for water in the bathtub and a corner of the sink for a cat. I arranged them in the order of overlap and placed GIFs between the layers. I'm trying to make a stream of water from a watering can, but it doesn't work out yet, a difficult task with falling water. Please note - you can not do it very carefully, everything will be smooth when applied, the boundaries of the layers are not visible. The main thing is to make the edge of the hole smooth, the rest is not important. The animated picture is here https://www.mediafire.com/file/d2ls9gm7bi2aw9...1%2583%25D0%25B7.avi/file |
| Posted by GaudiGalopin3324 at Jun 28, 2024, 11:49:56 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising I made water from the overhead shower. It is a difficult task for me, I continue to experiment.. https://www.mediafire.com/file/omb0hmnbchkpu7...0%25BE%25D0%25B9.avi/file |
| Posted by Keet at Jun 29, 2024, 12:07:56 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising That water would look great for a waterfall! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by GaudiGalopin3324 at Jun 29, 2024, 9:34:57 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising This is the case when you are trying to create a hyperrealistic picture. And one mistake spoils everything at once. There is no such failure in the traditional SH3D visualization system, because there is no such task initially. Visualizations in ordinary SH3D do not cause such criticism, because there is no task of hyperreality. The most annoying thing is that I made transparent water, it is in the working file!! But there's no way I can keep it like this, I'm doing something wrong. All the time, opaque colored water is obtained, as if foamed. |
| Posted by GaudiGalopin3324 at Jun 29, 2024, 9:42:41 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising Partially, the situation with the failure is saved by the frivolity of the author's attitude, humor. If you try not to smile, it's harder. ![]() |
| Posted by Ceciliabr at Jun 29, 2024, 11:34:10 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising Hi! Watched your video. Nice idea. Let me give you a little tip: When you want to insert gifs, you should first import some models of people in the right size and render it. That way you get the right size and perspective on you gifs. Try that and you will be amazed how real it can look. Cecilia |
| Posted by GaudiGalopin3324 at Jun 29, 2024, 11:55:20 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising I am happy and very impressed by your attention!! Thank you, very good correct advice. I will definitely use it. Please, I really look forward to your advice. You are my ideal in the world of illusion. Your achievements are beyond my desire, thank you again. ![]() |
Current timezone is GMT Sep 14, 2026, 6:46:45 AM |
