Print at Aug 12, 2026, 3:37:04 PM View all posts in this thread on one page
Posted by KitchM at Feb 22, 2023, 8:31:56 PM
Create Rooms with Walls
How does the user create a room with walls at the same time? Using Create Room seems to leave off the walls.
Posted by Puybaret at Feb 22, 2023, 8:54:01 PM
Re: Create Rooms with Walls
It’s not possible, but using the wall creation tool, you can create the walls around a room, by double clicking on it.
Posted by KitchM at Feb 23, 2023, 4:57:33 PM
After a little trial and error, and with your tip, I was able to figure it out.
1. Use Create Rooms button, and create the room.
2. Then select the Create Walls button, and only then double-click on the room.
The user could double-click all day if not choosing the correct icon button.
Thanks for the tip. I will add this to my how-to article.
_____________________________________________________________
By the way, I tried to post this and got an error from your server:
HTTP Status 403 – Forbidden
Type Status Report
Message Spamming IP address detected
Description The server understood the request but refuses to authorize it.
Apache Tomcat/9.0.31 (Debian)
I had to change browsers.
