Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create Rooms with Walls |
| Print at Aug 12, 2026, 4:20:13 PM | |
| Posted by KitchM at Feb 22, 2023, 8:31:56 PM |
Create Rooms with Walls How does the user create a room with walls at the same time? Using Create Room seems to leave off the walls. |
| Posted by Puybaret at Feb 22, 2023, 8:54:01 PM |
Re: Create Rooms with Walls It’s not possible, but using the wall creation tool, you can create the walls around a room, by double clicking on it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KitchM at Feb 23, 2023, 4:57:33 PM |
Re: Create Rooms with Walls After a little trial and error, and with your tip, I was able to figure it out. 1. Use Create Rooms button, and create the room. 2. Then select the Create Walls button, and only then double-click on the room. The user could double-click all day if not choosing the correct icon button. Thanks for the tip. I will add this to my how-to article. _____________________________________________________________ By the way, I tried to post this and got an error from your server: HTTP Status 403 – Forbidden Type Status Report Message Spamming IP address detected Description The server understood the request but refuses to authorize it. Apache Tomcat/9.0.31 (Debian) I had to change browsers. |
Current timezone is GMT Aug 12, 2026, 4:20:13 PM |
