Print at Oct 1, 2026, 9:33:04 PM
Posted by Jeypee at Jan 30, 2023, 2:48:20 PM
confused   Silent Installation with 64bit dont work
Hello,
today i tried to install the newest Version 7.0.2 over command line in 64 bit.
All Parameters are visible with "SweetHome3d-7.0.2.exe" /?
First i started with the parameter "/SAVEINF="SweetHome3D.inf"
Installed in "64-bit" - all ok. After that i uninstalled it.
Next i tried with "/loadinf="SweetHome3D.inf" but it installed in "C:\ProgramFiles (x86)" < 32 bit.
In the Inf File is an Parameter: Dir="C:\Program Files\Sweet Home 3D"
I also tried with "/DIR="C:\Program Files\Sweet Home 3D" but it installed also in the 32-bit Directory ?!
My Problem is that no silent installation works. Here my parameter:
SweetHome3d-7.0.2.exe /SILENT /NORESTART /NOCANCEL /DIR="C:\Program Files\Sweet Home 3d" /LOG="SweetHome3d.log"
Dont work - just 32-bit. Only manuel 64-bit works :-(
Please help
Posted by Puybaret at Jan 31, 2023, 8:09:52 AM
Re: Silent Installation with 64bit dont work
Adding /os.arch=x64 parameter should do the trick. See also installer parameters described at the end of this article.
Posted by Jeypee at Jan 31, 2023, 9:52:03 AM
smile   Re: Silent Installation with 64bit dont work
Thank you very much. That works.
Should be stay here:
http://www.sweethome3d.com/faq.jsp#installation
