Print at Sep 20, 2026, 7:32:10 PM
Posts: 19   Pages: 2   [ Previous Page | 1 2 ]
Posted by dorin at Jan 6, 2024, 10:06:18 PM
Re: "Tools" menu and panel missing from all installations - is there a "Configuration Manager"?
IMHO you use the repository version of SH3D.
WRONG! as I've explained several times on this forum.
I've conclude this around 10 years ago.
Under linux, any kind of, use the installer provided by the original creator from HERE .
FORGET THE REPOSITORY in the SH3D case.
Read and fallow the instructions.
In this way you will avoid a lot of headaches.
If this is not the case, post here the terminal output to see what happen.
Posted by pa_trick at Jan 6, 2024, 11:58:16 PM
For my first install of Sweethome3D, I installed the snap version V6.6 through the Ubuntu Application installer. After the first series of problems I had, I removed that installation then installed the V7.2 from http://www.sweethome3d.com/download.jsp following the instructions you posted some time ago. It was on that install that I installed the Plugin Manager and discovered that several of the plugins (including roof generator) are not compatible with V7.2.
In an attempt to get a version that the Roof Generator will work on, I removed the V7.2 installation and reinstall the Snap version V6.6. I am still getting the error message:
Posted by dorin at Jan 7, 2024, 7:35:18 AM
Ok.
In this case verify in Help->About to see your SH3D version.
The Roof Generator work with >=7.2 so you probably still run an older version.
If you have a shortcut for launch verify the path.
Posted by pa_trick at Jan 7, 2024, 4:44:21 PM
This is what help->about tells me:
Posted by dorin at Jan 7, 2024, 7:21:52 PM
Great!
You still run 6.6.
If you really fallow the official instructions (OR mine) on how to install on linux,
go in the extracted folder SweetHome3D-7.2 and run the SweetHome3D file
(usually double-click on it and choose execute OR run as a program).
After launch check again the version.
You must have 7.2.
If that's true, update all settings related with SH3D (shortcut, file association, menu entry etc.)
To be sure, you could move (delete) the old folder (SweetHome3D-6.6) and you will see whats works and whats don't (shortcuts).
Posted by Keet at Jan 7, 2024, 7:35:07 PM
If you get black artifacts on Linux use the script SweetHome3D-Java3D-1_5_2 instead of SweetHome3D to start SweetHome3D.
Posted by ChecMark at Apr 23, 2026, 1:26:06 AM
Also a Newbie and totally lost. Trying to design a kitchen and can't even find a fridge! Numerous videos say to click on "Tools" but I don't have that in my menu. I see someone here said there is no "Tools" in the installation. Ideally I would like to use the Cabinet Maker but I can't find that anywhere either. Appreciate any help.
Posted by Keet at Apr 23, 2026, 6:28:11 AM
See my answer here
Posted by dorin at Apr 23, 2026, 9:01:56 PM
Sorry for double post.
Tools menu IT IS NOT a default menu item.
It appear only if you install at least a plugin which programed it(Cabinet maker, Roof generator, Advanced editing etc).
Install Cabinet Maker and you will have Tools menu after you restart the SH3D.
