Print at Aug 19, 2026, 1:31:56 AM View all posts in this thread on one page
Posted by NickDonato at Dec 13, 2022, 11:11:59 AM
Translucent walls/panes with no reflection???
Hi Everyone,
I'm looking for some expert help. I'm working on a design for a dedicated home theater. I have everything just right, except for 1 detail... The side walls of the theater will have fabric walls to hide the surround speakers, but we are going to light the speakers so they "semi" show through.
I understand how to make "translucent walls/panes". But I can't find a way to get rid of the reflection?!?!?!
I've searched everywhere and seen a few threads on the "mirror trick". I messed around with colors, textures, the "d" parameter in the .mtl file as well as Ns and Ni, I've gone all the render settings.... and for the life of me, I can not get a surface to put on the sidewalls that will render as TRANSLUCENT w/ NO REFECTIONS?!?!?!?!?!
See pics below... Thanks sooooo much in advance for your help :)
Posted by NickDonato at Dec 14, 2022, 3:27:02 PM
Re: Translucent walls/panes with no reflection???
Here's the pics... The walls that cover the speakers are slightly (only 10%) translucent. But how can I keep them translucent with a flat/matt finish so there's no reflections???...These walls should be fabric walls, not glass.
Posted by NickDonato at Dec 14, 2022, 4:26:19 PM
Link to pictures...
https://postimg.cc/bdVW3zh7
Posted by Puybaret at Dec 15, 2022, 7:20:34 PM
Instead of playing with "d" MTL parameter, maybe you could try to use a half transparent texture. You could also try change the renderer quality to the highest level which render shiny objects with a more glossy effect.
Posted by NickDonato at Dec 15, 2022, 8:35:59 PM
Puybaret, THAT'S PERFECT!!!... I found another thread that had semi-transparent png files to download, applied them as texture, and it works FANTASTIC!!!!!
Thanks sooooooooo much for the great tip!!!!!! :D
