Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Translucent walls/panes with no reflection??? |
| Print at Aug 19, 2026, 2:34:05 AM | |
| Posted by NickDonato at Dec 13, 2022, 11:11:59 AM |
Translucent walls/panes with no reflection??? Hi Everyone, I'm looking for some expert help. I'm working on a design for a dedicated home theater. I have everything just right, except for 1 detail... The side walls of the theater will have fabric walls to hide the surround speakers, but we are going to light the speakers so they "semi" show through. I understand how to make "translucent walls/panes". But I can't find a way to get rid of the reflection?!?!?! I've searched everywhere and seen a few threads on the "mirror trick". I messed around with colors, textures, the "d" parameter in the .mtl file as well as Ns and Ni, I've gone all the render settings.... and for the life of me, I can not get a surface to put on the sidewalls that will render as TRANSLUCENT w/ NO REFECTIONS?!?!?!?!?! See pics below... Thanks sooooo much in advance for your help :) ![]() ![]() |
| Posted by NickDonato at Dec 14, 2022, 3:27:02 PM |
Re: Translucent walls/panes with no reflection??? Here's the pics... The walls that cover the speakers are slightly (only 10%) translucent. But how can I keep them translucent with a flat/matt finish so there's no reflections???...These walls should be fabric walls, not glass. ![]() |
| Posted by NickDonato at Dec 14, 2022, 4:26:19 PM |
Re: Translucent walls/panes with no reflection??? Link to pictures... https://postimg.cc/bdVW3zh7 |
| Posted by Puybaret at Dec 15, 2022, 7:20:34 PM |
Re: Translucent walls/panes with no reflection??? Instead of playing with "d" MTL parameter, maybe you could try to use a half transparent texture. You could also try change the renderer quality to the highest level which render shiny objects with a more glossy effect. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by NickDonato at Dec 15, 2022, 8:35:59 PM |
Re: Translucent walls/panes with no reflection??? Instead of playing with "d" MTL parameter, maybe you could try to use a half transparent texture. You could also try change the renderer quality to the highest level which render shiny objects with a more glossy effect. Puybaret, THAT'S PERFECT!!!... I found another thread that had semi-transparent png files to download, applied them as texture, and it works FANTASTIC!!!!! Thanks sooooooooo much for the great tip!!!!!! :D |
Current timezone is GMT Aug 19, 2026, 2:34:05 AM |
