Print at Oct 6, 2026, 12:55:15 AM
Posted by decard at Aug 30, 2022, 8:38:57 AM
Added Plugins ... Appearance
i have added all (applicable) plugins
do they generally just present as additional menu options within existing menus, eg the Advanced Editing add-on that was recommended?
at the moment, the only one i can actually see separately is the Automatic Dimensioning (which works very nicely, thank you someone)
so, to take the above example, just WHAT are the additional options that Advanced Editing add (and where are they)?
Posted by hansmex at Aug 30, 2022, 10:38:33 AM
Re: Added Plugins ... Appearance
Seems you have a persistent habit of ignoring HELP or info about plugins in this forum or on Sourceforge. I hope you're not expecting that for your sake we replicate all that info here...??
Posted by Puybaret at Aug 30, 2022, 2:36:27 PM
Note that the read more links in the Plug-ins page are also there for help purpose.
Posted by decard at Aug 31, 2022, 9:43:13 AM
what you say is not true and is unwarranted; but i will refrain from profanity (with some difficulty)
Posted by dorin at Aug 31, 2022, 11:36:39 AM
Look at right on the toolbar icons. There is at least 5 icons of this plugin:
- rotate selected
- move selected
- flip selected
- resize selected
- edit points
The last two I used frequently.
And many others under other menus.
If you don't see it, try to maximize the window until you see help icon.
Also, some plugins work ONLY with installed SH3D version.
