Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Windows 11 - not possible to open/save/save-as |
| Print at Jun 19, 2026, 9:48:42 AM | |
| Posted by BaaronHaffax at Aug 24, 2022, 6:17:51 PM |
Windows 11 - not possible to open/save/save-as Dear all, I downloaded version 7.0.2 and installed it. I use windows 11 (updated frequently), Java is also up-to-date. I can work with the software without any problem, also added some libraries from github. I've been working with the software some years ago. No issue so far, but as soon as I try to open a file ("open" dialogue) nothing happens. Same when I try to save or save-as, nothing happens. When I try to close the application it asks me if I wanted to safe the progress - when I click save nothing happens, no window pops up for me to choose the destination. What I tried so far: - Installing on Drive C (32 and 64 bit) - Installing on another drive (also both) - run as admin - uninstalling, removing all libraries, reboot, install again (same procedure as above) - tried compatibility mode - use of keys (Strg+O, Strg+S), Strg+Shift+S starts the screenshot mode, but nothing opens the "Explorer-Window" Nothing could solve the issue so far. Does anyone have an idea how to solve this? Thzank you in advance! |
| Posted by Puybaret at Aug 24, 2022, 7:15:59 PM |
Re: Windows 11 - not possible to open/save/save-as Maybe check that security settings don't forbid you to save some files from Sweet Home 3D application, following these instructions. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by BaaronHaffax at Aug 25, 2022, 7:06:04 PM |
Re: Windows 11 - not possible to open/save/save-as Dear Puybaret, thanks for the reply! I checked the setting, but my "Windows Security" is disabled though I use Norton 360. I checked the settings of this Application aswell, but even disabling the full package and looking at the detailed history does neither give any useful information nor make any difference... Best regards |
| Posted by Puybaret at Aug 25, 2022, 7:31:52 PM |
Re: Windows 11 - not possible to open/save/save-as Can you download a demo of the Gallery and try to open it by double-clicking on the downloaded file? If it works, try to modify it and save it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by BaaronHaffax at Aug 25, 2022, 8:12:55 PM |
Re: Windows 11 - not possible to open/save/save-as I downloaded the file, opened it by double-clickin, changed something and hit "save". That did actually work! "open" or "save-as" still does not work, but the changes I did were saved. |
| Posted by Puybaret at Aug 25, 2022, 8:23:29 PM |
Re: Windows 11 - not possible to open/save/save-as At least, you can start from an existing file and modify it. Nevertheless, it would be nice to understand why the file dialog box doesn't appear. Could you run Sweet Home 3D from the command line as explained here to get logs when you select Open or Save as menu item? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Arbor at Aug 25, 2022, 8:52:26 PM |
Re: Windows 11 - not possible to open/save/save-as I wanted to share that the same issue is occurring for me as well. I installed 7.0.2 today and am not able to save my work. I tried using a gallery file to alter and am still unable to save. I tried to launch from command line as advised above, but nothing is writing to my designated log file when I perform actions in the client. |
| Posted by Puybaret at Aug 25, 2022, 11:31:15 PM |
Re: Windows 11 - not possible to open/save/save-as @Arbor What error does the program report when you try to save (not save as) an existing file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by BaaronHaffax at Aug 25, 2022, 11:47:05 PM |
Re: Windows 11 - not possible to open/save/save-as I tried to use the command "SweetHome3D.exe -log MyLogFile.log", first time the file was created writing "system could not find the file" (in german ;-) ), another try and the system did not even create this file... |
| Posted by Arbor at Aug 26, 2022, 3:39:34 AM |
Re: Windows 11 - not possible to open/save/save-as No error messages presents for me, it just does not perform the save. The asterisk still appears by the filename in the upper corner. When attempting to close the program, it states the file has not been saved and prompts to save. It still does not save when following the prompt. |
| Posted by BaaronHaffax at Aug 26, 2022, 12:41:00 PM |
Re: Windows 11 - not possible to open/save/save-as Correct, when I do not open an existing document, the changed will be saved (manually or by clicking "save" on closing), it is not possible to open or save-as, the window to choose a file/filename does not appear. |
| Posted by Puybaret at Aug 26, 2022, 3:18:38 PM |
Re: Windows 11 - not possible to open/save/save-as I tried to use the command "SweetHome3D.exe -log MyLogFile.log" This command was just a suggestion from starrunner, you should rather use a command like:"C:\Program Files\Sweet Home 3D\SweetHome3D.exe" 2>MyLogFile.log---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by BaaronHaffax at Aug 26, 2022, 4:07:42 PM |
Re: Windows 11 - not possible to open/save/save-as I finally did it! I opened the "sample" file and deleted all walls and interriour. Then I wanted to delete the "background" picture - editting was possible, but no opening of a new one. So I deleted the background file... Tried to "open" a new file - tada! "Open" dialog appeared, and from that time I was able to open, save and safe-as any file! Finally it worked, no clue why, but now it is fine again! By the way, I also tried the line you posted, no difference - no log-file was created. Tzhanks for your support!! |
Current timezone is GMT Jun 19, 2026, 9:48:42 AM |
