Print at Aug 24, 2026, 11:54:12 PM
Posted by T_R at Aug 21, 2022, 6:32:10 AM
my Wishlist
A small wish:
1.)Be able to change the order of tabs" ( niveous) without restriction of level.
2.) Be Abel to MARK multiple nivous and copy in a new project.
Thx
T.
Laptop :ThinkPad 490, WIN11Pro, 64Bit, 8GBRam, 6T Harddrive
Never give Up!
Posted by Puybaret at Aug 21, 2022, 12:42:25 PM
Re: my Wishlist
Levels are listed in the order of their elevation, and for the levels at the same elevation, in the order set with the arrows at the right of the levels list in the level modification panel (see Levels visibility and order section in this article).
Posted by T_R at Aug 22, 2022, 3:24:15 PM
Re: my Wishlist
Yes I got this. But it is not always Handy on this way. Like: you want switch on parts of the project in order of the levels.or I have to do more work on one level, I like to have this on place one. Levels in priority... Do levels are not necessarily represent a altitude level, more a working tap to separate items for easy development.
Never give Up!
Posted by Keet at Aug 22, 2022, 4:46:33 PM
Re: my Wishlist
If you don't use the levels for altitude you can give each level the same elevation and order them using the arrows in the modify level dialogue. It's not the correct use of levels but for your case it might be the solution.
