Print at Sep 22, 2026, 1:57:50 AM View all posts in this thread on one page
Posted by rotoped123 at Mar 25, 2022, 4:59:06 PM
Thickness of the wall
Hi, I'm a newbie and would need an explanation of drawing walls and surfaces.
I draw the surface of a room and I want to draw the walls but with different thicknesses. When I change the thickness, the floor creeps into the wall. Then I get different dimensions and room area. Where am I going wrong?
THX
Posted by Puybaret at Mar 25, 2022, 6:45:55 PM
Re: Thickness of the wall
Walls and rooms are not bound. Just move the the room corners afterwards.
Posted by rotoped123 at Mar 26, 2022, 4:23:08 PM
So you recommend me.... paint walls with my thickness and after that create a room? Can you recommend any video with basic creating room and wall?
Posted by rotoped123 at Mar 26, 2022, 4:36:59 PM
When I move the wall to the corner......it is not exact. Maybe I describe what I want to. I want to create a blueprint of the flat - walls, surface, area of the floor with cote. It is enough for me.
Posted by sjb007 at Mar 27, 2022, 12:40:34 AM
Draw your walls first. Set their thicknesses as required. Position them exactly where you want. Switch to the room tool and double-click in the space between the walls. SH3D will fill the empty area with a room automatically provided it is an enclosed space. i.e. do not leave gaps in the perimeter. Door objects do not count as gaps.
