Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Thickness of the wall |
| Print at Sep 22, 2026, 3:09:44 AM | |
| Posted by rotoped123 at Mar 25, 2022, 4:59:06 PM |
Thickness of the wall Hi, I'm a newbie and would need an explanation of drawing walls and surfaces. I draw the surface of a room and I want to draw the walls but with different thicknesses. When I change the thickness, the floor creeps into the wall. Then I get different dimensions and room area. Where am I going wrong? THX |
| Posted by Puybaret at Mar 25, 2022, 6:45:55 PM |
Re: Thickness of the wall Walls and rooms are not bound. Just move the the room corners afterwards. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by rotoped123 at Mar 26, 2022, 4:23:08 PM |
Re: Thickness of the wall So you recommend me.... paint walls with my thickness and after that create a room? Can you recommend any video with basic creating room and wall? |
| Posted by rotoped123 at Mar 26, 2022, 4:36:59 PM |
Re: Thickness of the wall When I move the wall to the corner......it is not exact. Maybe I describe what I want to. I want to create a blueprint of the flat - walls, surface, area of the floor with cote. It is enough for me. |
| Posted by sjb007 at Mar 27, 2022, 12:40:34 AM |
Re: Thickness of the wall Draw your walls first. Set their thicknesses as required. Position them exactly where you want. Switch to the room tool and double-click in the space between the walls. SH3D will fill the empty area with a room automatically provided it is an enclosed space. i.e. do not leave gaps in the perimeter. Door objects do not count as gaps. |
Current timezone is GMT Sep 22, 2026, 3:09:44 AM |
