Print at Sep 24, 2026, 4:10:33 PM View all posts in this thread on one page
Posted by gernith at Nov 8, 2009, 4:52:05 PM
Is this normal?
Every now and then I get stuck in this window, and I can't find a way out. I can't see any of the walls I've created, or the gridlines to draw them on? Is this a known problem?
Posted by Puybaret at Nov 9, 2009, 8:37:19 PM
Re: Is this normal?
It looks like this fixed bug, but probably a little different.
Please send me your Sweet Home 3D file or/and try this:
1. Launch Console program found in /Applications/Utilities folder and click on Clear display.
2. Launch Sweet Home 3D and open your file.
3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here.
Posted by gernith at Nov 10, 2009, 6:56:40 PM
Re: Is this normal?
Thanks for the help. If I remember correctly, the file is only a few walls as I was just learning the program. Here's the log, I'll send the file from my yahoo email account.
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Exception in thread "AWT-EventQueue-0" javax.media.j3d.BadTransformException: TransformGroup: non-affine transform
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.media.j3d.TransformGroup.setTransform(TransformGroup.java:137)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.updateViewPlatformTransform(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.createUniverse(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.access$100(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:68)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:175)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:122)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.processComponentEvent(Component.java:5434)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.processEvent(Component.java:5382)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Container.processEvent(Container.java:2010)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Window.processEvent(Window.java:1184)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.dispatchEventImpl(Component.java:4068)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Container.dispatchEventImpl(Container.java:2068)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Window.dispatchEventImpl(Window.java:1801)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.dispatchEvent(Component.java:3903)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point.
11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGPointApplyInverseAffineTransform: singular matrix.
Posted by gernith at Nov 25, 2009, 3:12:04 AM
Re: Is this normal?
Any thoughts? More info I can provide?
Posted by gernith at Dec 27, 2009, 5:26:23 PM
Re: Is this normal?
Downloading the new 2.2, I still get the same issues with the file I sent you. I think I may have narrored it down to the "double electric outlet" http://www.sweethome3d.eu/models/contributions/electricOutlet2.zip
adding it to the model seems to cause the error.
Posted by Puybaret at Dec 31, 2009, 3:39:43 PM
Re: Is this normal?
I don't know how, but you succeeded to set a null value for the depth of the electric outlet placed in your home. If you know how to reproduce this problem, please describe it here.
Posted by gernith at Dec 31, 2009, 11:36:17 PM
Re: Is this normal?
From the furniture menu I chose import furniture, find models, which caused http://www.sweethome3d.eu/importModels.jsp to load in my safari web browser. I chose the "Double electric outlet" which downloaded and expanded "electricOutlet2.obj". From the furniture menu I chose import furniture, choose model, and located the "electricOutlet2.obj" file. The continue, continue, continue, finish, without changing any dimensions. Here's what it lists the dimensions as:
Then I clicked and dragged "electricOutlet2" on to a wall in the floor plan. This is when the problem occurs.
