Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Is this normal? |
| Print at Sep 24, 2026, 5:26:06 PM | |
| Posted by gernith at Nov 8, 2009, 4:52:05 PM |
Is this normal? Every now and then I get stuck in this window, and I can't find a way out. I can't see any of the walls I've created, or the gridlines to draw them on? Is this a known problem? ![]() |
| Posted by Puybaret at Nov 9, 2009, 8:37:19 PM |
Re: Is this normal? It looks like this fixed bug, but probably a little different. Please send me your Sweet Home 3D file or/and try this: 1. Launch Console program found in /Applications/Utilities folder and click on Clear display. 2. Launch Sweet Home 3D and open your file. 3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by gernith at Nov 10, 2009, 6:56:40 PM |
Re: Is this normal? Thanks for the help. If I remember correctly, the file is only a few walls as I was just learning the program. Here's the log, I'll send the file from my yahoo email account. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Exception in thread "AWT-EventQueue-0" javax.media.j3d.BadTransformException: TransformGroup: non-affine transform 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.media.j3d.TransformGroup.setTransform(TransformGroup.java:137) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.updateViewPlatformTransform(Unknown Source) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.createUniverse(Unknown Source) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D.access$100(Unknown Source) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at com.eteks.sweethome3d.swing.HomeComponent3D$1.ancestorAdded(Unknown Source) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.swing.AncestorNotifier.fireAncestorAdded(AncestorNotifier.java:68) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at javax.swing.AncestorNotifier.componentShown(AncestorNotifier.java:175) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:122) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.AWTEventMulticaster.componentShown(AWTEventMulticaster.java:121) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.processComponentEvent(Component.java:5434) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.processEvent(Component.java:5382) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Container.processEvent(Container.java:2010) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Window.processEvent(Window.java:1184) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.dispatchEventImpl(Component.java:4068) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Container.dispatchEventImpl(Container.java:2068) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Window.dispatchEventImpl(Window.java:1801) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.Component.dispatchEvent(Component.java:3903) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110) 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGPointApplyInverseAffineTransform: singular matrix. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGPointApplyInverseAffineTransform: singular matrix. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. 11/10/09 12:35:52 PM [0x0-0x17017].com.eteks.sweethome3d.SweetHome3D[142] Tue Nov 10 12:35:52 ssds-macbook-pro-2.local JavaApplicationStub[142] <Error>: CGContextClosePath: no current point. |
| Posted by gernith at Nov 25, 2009, 3:12:04 AM |
Re: Is this normal? Any thoughts? More info I can provide? |
| Posted by gernith at Dec 27, 2009, 5:26:23 PM |
Re: Is this normal? Downloading the new 2.2, I still get the same issues with the file I sent you. I think I may have narrored it down to the "double electric outlet" http://www.sweethome3d.eu/models/contributions/electricOutlet2.zip adding it to the model seems to cause the error. |
| Posted by Puybaret at Dec 31, 2009, 3:39:43 PM |
Re: Is this normal? I don't know how, but you succeeded to set a null value for the depth of the electric outlet placed in your home. If you know how to reproduce this problem, please describe it here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by gernith at Dec 31, 2009, 11:36:17 PM |
Re: Is this normal? From the furniture menu I chose import furniture, find models, which caused http://www.sweethome3d.eu/importModels.jsp to load in my safari web browser. I chose the "Double electric outlet" which downloaded and expanded "electricOutlet2.obj". From the furniture menu I chose import furniture, choose model, and located the "electricOutlet2.obj" file. The continue, continue, continue, finish, without changing any dimensions. Here's what it lists the dimensions as: Then I clicked and dragged "electricOutlet2" on to a wall in the floor plan. This is when the problem occurs. |
Current timezone is GMT Sep 24, 2026, 5:26:06 PM |
