Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: PluginDevToolkit: the dynamic plugin loader for developers |
| Print at Sep 23, 2026, 6:07:20 PM | |
| Posted by Daniels118 at Jan 11, 2022, 7:14:01 PM |
PluginDevToolkit: the dynamic plugin loader for developersHello SH3D developers! While writing my plugins the code become a bit complex, and sometime it required a trial and error approach. The major drawback using this method is that every small change to the code requires exporting the project as jar into the plugins folder and restart SH3D, which could be a big waste of time because of the splash screen and eventually loading a large test home from the disk... not taking into account for temporary changes to the home that would be lost, camera positioning, and so on. Before starting to write my last plugin I decided to create a system to overcome these limitations. The system worked like a charm, and I've extensively tested it almost for a month while working to the Wirings plugin, so I decided to share it to help the plugins ecosystem growing faster .Integrating the system into existing plugins is a matter of minutes. First you have to setup your plugin project as described in the plug-in developer's guide, completing the Debugging the plug-in step in order to have a working run configuration. If you experience trouble with this step see the troubleshooting section at the end of this post. Once you have a working run configuration follow these simple steps:
When you're ready to release your plugin to the public there is no need to remove the customizations, you can safely leave them in place, but don't forget to rebuild the sh3p package before distributing it! Lifecycle management To avoid unexpected results when reloading the plugin at runtime, you should correctly implement the plugin lifecycle management by overriding the init() and destroy() methods in your real plugin class. Everytime a change is detected in class files, the DynamicPluginLoader calls the destroy() method to let you release any allocated resource; your plugin is then replaced by a fresh new instance of the new class and the init() method is called to let you initialize your plugin. Limitations
Examples You can download this example which is the VolumePlugin proposed in the developer guide already configured to work with the PluginDevToolkit, you just have to add the SweetHome3D-x.y.jar from your local filesystem. Try to change the output unit from m3 to liters while the SH3D is running! Troubleshooting If you didn't succeed to run SH3D from Eclipse getting the following exception: Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException: Cannot invoke "com.jogamp.nativewindow.awt.AWTGraphicsConfiguration.getAWTGraphicsConfiguration()" because "<local3>" is nullHope you have nice times developing SH3D plugins! Cheers! ![]() |
| Posted by Puybaret at Jan 12, 2022, 6:25:51 PM |
Re: PluginDevToolkit: the dynamic plugin loader for developers Nice tool! ![]() Please add a license to your source code if you want developers to use it (I would suggest LGPL 2.0 if you're ok). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Daniels118 at Jan 13, 2022, 1:03:20 PM |
Re: PluginDevToolkit: the dynamic plugin loader for developers Salut Emmanuel, I have added the LGPL v3 to both the toolkit and example archives :) Thank you Daniele |
| Posted by Daniels118 at Mar 23, 2022, 1:21:26 PM |
Re: PluginDevToolkit: the dynamic plugin loader for developers The toolkit has been updated to version 1.1, the download links stay the same. Changelog:
Current timezone is GMT Sep 23, 2026, 6:07:20 PM |
