Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Rendering error |
| Print at Sep 20, 2026, 3:33:19 PM | |
| Posted by stelvio.rosset at Sep 25, 2021, 7:23:45 PM |
Rendering error Hello, I have created a relative simple project, one level of environment with many trees and a lake, then couple of hills as second level (created with geo triangles and geo cones) and then two buildings designed in other additional 4 layers. When try to render in High Quality the process stop with the error: java.lang.OutOfMemoryError: Java heap space Thanks for help Stelvio |
| Posted by Puybaret at Sep 26, 2021, 11:07:10 AM |
Re: Rendering error If you use Sweet Home 3D under Windows, reinstall it to try the 64 bit version and if it’s still not enough, try to increase the maximum memory used by the program. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 3:33:19 PM |
