Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Can't get SH3D to run on my new Surface Pro X |
| Print at Aug 20, 2026, 6:09:00 AM | View all posts in this thread on one page |
| Posted by LaundrySolutions at Aug 28, 2021, 4:28:02 AM |
Can't get SH3D to run on my new Surface Pro X Hi all, I'm experiencing the same issues as a lot of other people re the fatal error in the rendering system etc. I've tried a range of workarounds including 32bit, running it with the ini file for Directx etc and have tried running it within Java etc but to no avail. Has anyone got any other ideas - I'm desperate Thanks Sean |
| Posted by Puybaret at Aug 28, 2021, 3:21:11 PM |
Re: Can't get SH3D to run on my new Surface Pro X If none of the solutions proposed in the FAQ works, you could try to set com.eteks.sweethome3d.j3d.useOffScreen3DView property to true, by writing the line -Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by LaundrySolutions at Sep 1, 2021, 9:25:11 AM |
Re: Can't get SH3D to run on my new Surface Pro X Thanks Emmanuel, I give it a try and let you know how it went. Cheers Sean |
| Posted by LaundrySolutions at Jul 21, 2022, 3:18:05 AM |
Re: Can't get SH3D to run on my new Surface Pro XHi everyone, Just an update, tried installing V7 and had the same result. If anyone has any other ideas..... |
| Posted by Puybaret at Jul 21, 2022, 4:19:15 PM |
Re: Can't get SH3D to run on my new Surface Pro X Your Surface Pro X contains an ARM processor, not an Intel processor, right? If it's the case, the installation program should be able to install a working 32 bit version running with DirectX, but I have no idea if it actually woks because the user arm64appcompatguy never answered about it in this thread. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 20, 2026, 6:09:00 AM |
