Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Switch off 3D / deactivate 3D |
| Print at Sep 6, 2026, 6:24:08 AM | |
| Posted by MyFlatinB at Aug 12, 2021, 6:38:41 PM |
Switch off 3D / deactivate 3D Hey, I did several searches here to find an answer but I did not succeed. As a beginner I am starting to draw the floor plan room by room by entering all the measurements. In the background the software is busy to always create the 3D view automatically in the bottom pane. I like the feature but do not need it yet. As it uses my processor to a good extent I prefer to deactivate the 3D creation as it slows down my system. I wonder that I did not find anything re/ this. Does this feature exist? If so, please give me a pointer. Thanks and regards, Manfred |
| Posted by hansmex at Aug 13, 2021, 12:36:49 PM |
Re: Switch off 3D / deactivate 3D As far as I know, you can't switch off the live 3D preview. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Aug 13, 2021, 4:30:37 PM |
Re: Switch off 3D / deactivate 3D You could try Sweet Home 2D (read the FAQ How can I disable 3D features in Sweet Home 3D?) but you won’t have top view icons in the plan. You could also hide the 3D view by moving the separator between the plan and the 3D view. Then you’ll have to close your file and reopen it to really stop updates in the 3D view. Updates will be computed again only once you’ll make the 3D view appear at screen. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MyFlatinB at Aug 16, 2021, 6:54:46 PM |
Re: Switch off 3D / deactivate 3D Yep - that did the trick. Thanks a lot. Cheers, Manfred |
Current timezone is GMT Sep 6, 2026, 6:24:08 AM |
