Print at Aug 25, 2026, 12:34:16 AM View all posts in this thread on one page
Posted by titust11 at May 4, 2021, 1:39:44 AM
I created and imported a trapezoidal window. How do I create wall hatch for it?
I don't understand why if I add a window from the SH3D built in
furniture library, I can insert it in a wall and I don't need a hatch, but if I create my own window, I need a hatch.
Guess what... if I have a non conventional (trapezoidal) window, there is no way to find a trapezoidal hatch for it.
I am stuck... please help
Guys I really like this application but it lacks some basic features.
Any idea?
Thanks
Posted by hansmex at May 4, 2021, 2:47:15 AM
Re: I created and imported a trapezoidal window. How do I create wall hatch for it?
When you import a model that you want to use as for our window, you need to check the box door-window. Read the user guide...
Posted by titust11 at May 4, 2021, 3:20:16 AM
Thanks but unfortunately if I do this, is cuts a rectangular hole in the wall. I don't know how to attach a picture to this forum to show you
Posted by Puybaret at May 4, 2021, 9:42:12 AM
Be sure that the wall where you placed the window has a null arc extent because Sweet Home 3D isn’t able to compute not rectangular shapes in round walls until now.
Would it be your case?
Posted by titust11 at May 4, 2021, 5:28:45 PM
My wall is not round
Posted by titust11 at May 4, 2021, 6:05:07 PM
You can see on YT - the window in the wall. It's ugly
https://youtu.be/8b5qNCE_Wq0
Je ne comprends pas pour quoi on ne peut pas trouver une solution a ce probleme
Posted by Puybaret at May 4, 2021, 6:48:18 PM
I just checked on my side with a similar hole in a wall and it worked with no problem.
Share you window model, it might be handy to understand your issue.
Attachment TrapezeWindow.sh3d (8492 bytes) (Download count: 609787)
Posted by titust11 at May 4, 2021, 10:14:43 PM
How do I attach a file in this forum?
Posted by titust11 at May 4, 2021, 10:29:12 PM
I have sent you an email with two attachments
Posted by Puybaret at May 5, 2021, 9:58:28 AM
The front face of your model is its border which is rectangular. Rotating it 90° in the second step of the Furniture import wizard will fix your issue.
