Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: I created and imported a trapezoidal window. How do I create wall hatch for it? |
| Print at Aug 25, 2026, 1:06:51 AM | |
| Posted by titust11 at May 4, 2021, 1:39:44 AM |
I created and imported a trapezoidal window. How do I create wall hatch for it? I don't understand why if I add a window from the SH3D built in furniture library, I can insert it in a wall and I don't need a hatch, but if I create my own window, I need a hatch. Guess what... if I have a non conventional (trapezoidal) window, there is no way to find a trapezoidal hatch for it. I am stuck... please help Guys I really like this application but it lacks some basic features. Any idea? Thanks |
| Posted by hansmex at May 4, 2021, 2:47:15 AM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? When you import a model that you want to use as for our window, you need to check the box door-window. Read the user guide... ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by titust11 at May 4, 2021, 3:20:16 AM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? Thanks but unfortunately if I do this, is cuts a rectangular hole in the wall. I don't know how to attach a picture to this forum to show you |
| Posted by Puybaret at May 4, 2021, 9:42:12 AM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? Be sure that the wall where you placed the window has a null arc extent because Sweet Home 3D isn’t able to compute not rectangular shapes in round walls until now. Would it be your case? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by titust11 at May 4, 2021, 5:28:45 PM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? My wall is not round |
| Posted by titust11 at May 4, 2021, 6:05:07 PM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? You can see on YT - the window in the wall. It's ugly https://youtu.be/8b5qNCE_Wq0 Je ne comprends pas pour quoi on ne peut pas trouver une solution a ce probleme |
| Posted by Puybaret at May 4, 2021, 6:48:18 PM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? I just checked on my side with a similar hole in a wall and it worked with no problem. Share you window model, it might be handy to understand your issue. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by titust11 at May 4, 2021, 10:14:43 PM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? How do I attach a file in this forum? |
| Posted by titust11 at May 4, 2021, 10:29:12 PM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? I have sent you an email with two attachments |
| Posted by Puybaret at May 5, 2021, 9:58:28 AM |
Re: I created and imported a trapezoidal window. How do I create wall hatch for it? The front face of your model is its border which is rectangular. Rotating it 90° in the second step of the Furniture import wizard will fix your issue. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 25, 2026, 1:06:51 AM |
