Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Scaling print to a page size |
| Print at Sep 24, 2026, 1:24:17 PM | View all posts in this thread on one page |
| Posted by tcchittyjr at Mar 24, 2021, 4:45:51 PM |
Scaling print to a page size I now know how to print a 2D view only. However, when I print the room I'm laying out, even though the scale is 20'x30', the printed image is small on an 8.5"x11" paper. How do I scale that image up to fit the page? I've tried various page settings, paper settings, and nothing seems to work. TIA, TomC |
| Posted by Puybaret at Mar 24, 2021, 4:49:15 PM |
Re: Scaling print to a page size Choose Best fit scale option in Page setup dialog box. It's also indicated in the help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by tcchittyjr at Mar 24, 2021, 7:15:43 PM |
Re: Scaling print to a page size Sorry, that doesn't work for me. The room is still very small. And, I did try that before I started this thread. |
| Posted by Puybaret at Mar 24, 2021, 8:14:01 PM |
Re: Scaling print to a page size You probably moved a small object far from your main plan, misleading Sweet Home 3D to compute a scale which includes this object. Choose Edit > Select All menu item then Plan> Zoom Out menu item to try to find and delete it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by tcchittyjr at Mar 24, 2021, 11:56:46 PM |
Re: Scaling print to a page size Yep, that did it. It was the compass, which I moved out of the way when I was creating the room. Thanks so much. |
Current timezone is GMT Sep 24, 2026, 1:24:17 PM |
