Print at Sep 24, 2026, 3:26:43 PM
Posted by tcchittyjr at Mar 24, 2021, 4:45:51 PM
Scaling print to a page size
I now know how to print a 2D view only. However, when I print the room I'm laying out, even though the scale is 20'x30', the printed image is small on an 8.5"x11" paper. How do I scale that image up to fit the page? I've tried various page settings, paper settings, and nothing seems to work.
TIA,
TomC
Posted by Puybaret at Mar 24, 2021, 4:49:15 PM
Re: Scaling print to a page size
Choose Best fit scale option in Page setup dialog box. It's also indicated in the help.
Posted by tcchittyjr at Mar 24, 2021, 7:15:43 PM
Sorry, that doesn't work for me. The room is still very small. And, I did try that before I started this thread.
Posted by Puybaret at Mar 24, 2021, 8:14:01 PM
You probably moved a small object far from your main plan, misleading Sweet Home 3D to compute a scale which includes this object.
Choose Edit > Select All menu item then Plan> Zoom Out menu item to try to find and delete it.
Posted by tcchittyjr at Mar 24, 2021, 11:56:46 PM
Yep, that did it. It was the compass, which I moved out of the way when I was creating the room. Thanks so much.
