Print at Sep 15, 2026, 6:52:40 AM
Posts: 36   Pages: 4   [ 1 2 3 4 | Next Page ]
Posted by dorin at Mar 14, 2021, 8:24:47 PM
Auto Dimensioning plugin
As usual, YAUP.
"The Hell are paved with good intentions"
This subject was on this tread but without source code.
I tray to reproduce and ad inner radius for curved walls.
Wile I'm not a programmer, use it with care!
Could be launch from Tools->AutoDimensioning... or from icon on toolbar.
The plugin with source code could be downloaded from AutoDimensioning plugin or from sourceforge
Some screenshots:
Good luck!
Posted by SeppoV12 at Mar 14, 2021, 11:25:49 PM
smile   Re: Auto Dimensioning plugin
After quick try: this works for me (and for others, I am sure)!
And when we think of these days there is a gem, really nice question 'Are you sore?' smile
Very usefull plugin, thanks again Dorin!
Seppo
Posted by dorin at Mar 15, 2021, 8:30:55 AM
Thanks Seppo!
Wasn't with intention. On next version will be "Are you sure?" sad
TODO also in next version:
- implement somehow the exterior walls;
- to align exterior dimensions;
- to add walls thickness.
At that moment, to align dimension lines, I don't see other solution than select the lines and than align them with another plug-in.
I will see what I can do or maybe someone else could do this.
Posted by hansmex at Mar 15, 2021, 9:49:25 AM
There's something to be learned everywhere.
yawp (v.) (or yaup)
c. 1300, yolpen, probably echoic variant of yelpen (see yelp ). Related: Yawped; yawping. The noun, in reference to speech, is recorded from 1835, now used chiefly in conscious echo of Whitman (1855).
yelp (v.)
Old English gielpan (West Saxon), gelpan (Anglian) "to boast, exult," from Proto-Germanic *gel- (source also of Old Saxon galpon, Old Norse gjalpa "to yelp," Old Norse gjalp "boasting," Old High German gelph "outcry"), from PIE root *ghel- (1) "to call, cry out." Meaning "utter a quick, sharp, bark or cry" is 1550s, probably from the noun. Related: Yelped; yelping.
Source
Posted by dorin at Mar 15, 2021, 2:59:26 PM
YAUP=Yet Another Useless Plugin
Posted by hansmex at Mar 15, 2021, 4:17:10 PM
That's what I said: There's something to be learned everywhere.
Hahahahaha - Hans
Posted by dorin at Mar 15, 2021, 9:00:58 PM
@ Hans
My unique neuron is a little bit lazy. blushing
I need a new test_dimensions file and I know You can do this.
Maybe a screenshot with how to look Your desire dimension lines. Especially for curved walls.
As You've already observe I've use one of Your file for my sample.
I need one or more files to cover as many possibly situations but also not too unavailing complex.
Posted by dorin at Mar 21, 2021, 12:29:57 PM
New version 1.1
Download AutoDimensioning v1.1 and from SourceForge .
@hansmex Many thanks for help!
You have to download this version because is a little bit different.
News:
- fix some bug in message and translations;
- implement exterior walls;
- add built area(s);
- all adds are in separate level at same elevation.
Some explanations:
Hint:
To have ONLY the built area chose "Only selected walls" with NO walls selected and check the "Add built areas"
The built area are composed by a room and a poly-line.
I need it probably for a roof plugin.
PS. Please verify my translations in English and french. I usually make a lot of mistakes.
Posted by reddy.shyam at Mar 22, 2021, 1:00:18 PM
Hi dorin,
Great plugin there! I was looking for something like this where I can see the dimensions of my entire plan. 👍🤝👌👏
May be a stupid question but is there a way where we can toggle this? I mean if dimensions visible, we should be able to turn off too. I would not want to see it on all the time but to check if anything altered. Hence checking. 🙂
Posted by Puybaret at Mar 22, 2021, 1:03:37 PM
Just make unviewable / viewable the level where dimensions are added.
