Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Angled Windows |
| Print at Sep 20, 2026, 8:00:29 PM | |
| Posted by stelvio.rosset at Mar 13, 2021, 11:45:37 AM |
Angled Windows Hello all, any suggestion how to create angled window? Example: ************ *-----------* *------------* *-------------* *--------------* *---------------* *----------------* ******************* Thanks for help. |
| Posted by SeppoV12 at Mar 14, 2021, 10:34:23 PM |
Re: Angled Windows I made couple angled windows with Sketchup Make 2017 (still free, I think). Those windows available if wanted. No idea how to create such with SH3D. ![]() Seppo |
| Posted by SeppoV12 at Mar 14, 2021, 10:39:16 PM |
Re: Angled Windows .. hope I understood correctly your sketch.. ![]() |
| Posted by stelvio.rosset at Mar 14, 2021, 11:00:36 PM |
Re: Angled Windows Hi Seppo, yes you got exactly the idea. Do you think I can import your model, if possible, into sh3d? |
| Posted by SeppoV12 at Mar 14, 2021, 11:51:44 PM |
Re: Angled Windows Smaller window and bigger window. Both are in .DAE -format so you can use Import Furniture to get them into SH3D. Inside and outside surfaces are different material so you can use different 'paint' for inside and outside parts. |
| Posted by SeppoV12 at Mar 15, 2021, 10:24:25 AM |
Re: Angled Windows Rendering these windows might show unwanted colors/materials 'cladding_stucco_white' and 'material' bleeding through. In this case use Modify furniture - Materials and make those materials invisible. I have not found other solution to remove them.. sorry |
| Posted by crackwood01 at Apr 16, 2021, 3:48:59 AM |
Re: Angled Windows Hi, using the shape generator plugin you can create your own window shape, set his opacity, then, export it as an obj file Shape Generator 1.2 Then you could add some boxes around it as the window frame. Export all the selection as an obj file Import the new obj file as a door on window and VOILĂ€ ![]() |
| Posted by SeppoV12 at Apr 26, 2021, 9:35:39 PM |
Re: Angled Windows Excellent solution, crackwood01 - uses only SH3D-tools AND - avoid all problems I mentioned when creating window with SketchUp This is the way I will make my windows! |
Current timezone is GMT Sep 20, 2026, 8:00:29 PM |
