Print at Aug 25, 2026, 9:49:46 AM View all posts in this thread on one page
Posted by Aissacf at Feb 9, 2021, 11:02:16 PM
3D printing...
Hi there,
I read with great interest last years' thread on 3D printing
and I wonder if Emmanuel
or others have experimented with 3D printing or if export of models to 3D printable formats is on the horizon.
Thanks!
Posted by Puybaret at Feb 10, 2021, 5:12:45 PM
Re: 3D printing...
As far as I know, the most used file format for 3D printing is STL and there are some OBJ to STL converters on the web, so it could worth a try. Just pay attention to very thin volumes like windows, ceilings and floors.
Posted by UbuntuBirdy at Feb 10, 2021, 6:13:23 PM
Re: 3D printing...
Most slicer software can directly import OBJ files, so no need to convert.
But if you scale down a building, the walls will be too thin to print. This means you have to first cheat thicker walls in SH3D and then you will be able to print it. But most of the furniture will be too filigree to be printed...
So, you see, printing objects which are designed in 1:1 scale is a lot of extra work!
Pascal
Posted by yayanm at Jan 13, 2022, 5:06:44 AM
Re: 3D printing...
This is my experience in 3D printing.
The problem I encountered during the process are
(1) No floor thickness on Level 0 (I can't control the value as in upper levels)
(2) I can't directly open *.obj file to slicer app (Creality Slice 4.8)
These are the steps I use to encounter both problems :
(1) Create floor on BricsCAD
(2) Export as *.dae
(3) Import as furniture into SH3D
(4) Select the parts that I'd like to print > 3D View > Export as obj
(5) Import the *.obj : using FreeCAD 0.19 > Import > Alias Mesh (Mesh)
(6) Select object as necessary > File > Export > *.stl
(7) Import the *.stl to slicer app, set the necessary parameters as needed and print
I hope my experience will help other SH3D users. Thanks.
Posted by Puybaret at Jan 13, 2022, 12:08:12 PM
Re: 3D printing...
I think the first two steps are not necessary. If you want to give a thickness to your floor in the exported OBJ file, just create a level and change its elevation with a negative value. Only the floor of the first level doesn't have any thickness.
Posted by UbuntuBirdy at Jan 13, 2022, 7:48:12 PM
Re: 3D printing...
And by god, don't use restricted slicers from the printer manufacturer! Just use Cura and you can save that converting to .stl too.
Pascal
