Print at Aug 18, 2026, 11:24:19 PM View all posts in this thread on one page
Posted by Bilfrost at Nov 17, 2020, 5:26:12 PM
"Copy as new furniture" grayed out
I am 99% sure that I have successfully done this in the past.... But now it doesn't work.
If I select a room and try to copy it as new furniture, the option is grayed out. I need to also select another object, and then it allows me to copy it.
Any idea about what might be happening? I don't need another object.... just the room.
Thanks!
Posted by Puybaret at Nov 17, 2020, 8:16:34 PM
Re: "Copy as new furniture" grayed out
Fortunately, you didn't bet on that feature because it's not possible to copy only rooms with the version 1.2 of CopyAsNewFurniture plug-in. I should modify it to allow to copy at least rooms at upper levels (the rooms at the lower level have no thickness and only one face, the reason why I didn't allow to copy them).
Posted by Bilfrost at Nov 17, 2020, 10:40:50 PM
I see what is happening. If "display ceiling" is checked, than it can be copied. However, than I have a ceiling that i didn't want in the first place. It can be made invisible, fortunately.
But yes, it would be helpful to be able to copy it.
Posted by Bilfrost at Nov 17, 2020, 10:42:15 PM
Use case: easy way to make object of different shape that might be needed for a design, eg countertops.
Posted by Puybaret at Nov 18, 2020, 12:08:24 PM
I just updated the plug-in to version 1.3 to allow the copy of a room with only its floor visible, but this will work only if the copied room is at an upper floor, otherwise it wouldn't have any thickness.
