Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: "Copy as new furniture" grayed out |
| Print at Aug 19, 2026, 12:46:14 AM | |
| Posted by Bilfrost at Nov 17, 2020, 5:26:12 PM |
"Copy as new furniture" grayed out I am 99% sure that I have successfully done this in the past.... But now it doesn't work. If I select a room and try to copy it as new furniture, the option is grayed out. I need to also select another object, and then it allows me to copy it. Any idea about what might be happening? I don't need another object.... just the room. Thanks! |
| Posted by Puybaret at Nov 17, 2020, 8:16:34 PM |
Re: "Copy as new furniture" grayed out Fortunately, you didn't bet on that feature because it's not possible to copy only rooms with the version 1.2 of CopyAsNewFurniture plug-in. I should modify it to allow to copy at least rooms at upper levels (the rooms at the lower level have no thickness and only one face, the reason why I didn't allow to copy them). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bilfrost at Nov 17, 2020, 10:40:50 PM |
Re: "Copy as new furniture" grayed out I see what is happening. If "display ceiling" is checked, than it can be copied. However, than I have a ceiling that i didn't want in the first place. It can be made invisible, fortunately. But yes, it would be helpful to be able to copy it. |
| Posted by Bilfrost at Nov 17, 2020, 10:42:15 PM |
Re: "Copy as new furniture" grayed out Use case: easy way to make object of different shape that might be needed for a design, eg countertops. |
| Posted by Puybaret at Nov 18, 2020, 12:08:24 PM |
Re: "Copy as new furniture" grayed out I just updated the plug-in to version 1.3 to allow the copy of a room with only its floor visible, but this will work only if the copied room is at an upper floor, otherwise it wouldn't have any thickness. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 19, 2026, 12:46:14 AM |
