Print at Aug 26, 2026, 3:43:10 AM
Posted by DerekvG at Oct 30, 2020, 12:57:52 AM
Re: SH3D on Ubuntu 20.04 LTS
You helped me, very much, but i think it's good practise to give feedback when it's solved, so when people read the issue they may get an idea how to solve it
In this case yout comments showed i needed to look elsewhere for the problem
Posted by UbuntuBirdy at Oct 30, 2020, 10:41:34 AM
Yes, I agree! It's absolutely important, that you tell us not only that your issue is solved, but how you have solved it!
Thanks for that!
Pascal
Posted by TechnoTarzan at May 31, 2024, 9:15:14 PM
Hola! I am jumping into this thread because I have a similar problem, but being somewhat of a n00b to Ubuntu, I am having difficulty following along. I am running 24.04 LTS 64-bit on Gnome 46 with Wayland. If you need more details just ask....
My problem is similar when I launch the icon from Nautilus, I right click and Run and it launches the SH3D-7.4 but terminal displays:
~/Downloads/SweetHome3D-7.4$ ./SweetHome3D
Gtk-Message: 11:49:42.052: Failed to load module "appmenu-gtk-module"
Gtk-Message: 11:49:42.057: Failed to load module "canberra-gtk-module"
Any advice is appreciated. Thanks for your work on this app! Going to layout a small house for my daughter.
Posted by TechnoTarzan at Jun 1, 2024, 9:27:51 PM
UPDATE: I was able to remove teh errors above by using these:
sudo apt-get install libcanberra-gtk-module
sudo ln -s /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libcanberra-gtk-module.so /usr/lib/libcanberra-gtk-module.so
sudo apt install appmenu-gtk2-module
sudo apt install appmenu-gtk3-module
When I execute the icon in the SH3D folder, it executes but terminal still loads and the instant I click on FILE to start any task, I get this message:
** (java:81951): WARNING **: 12:25:31.677: Invalid borders specified for theme pixmap:
/usr/share/themes/Breeze/gtk-2.0/../assets/line-h.png,
borders don't fit within the image
** (java:81951): WARNING **: 12:25:31.677: invalid source position for vertical gradient
** (java:81951): WARNING **: 12:25:31.678: invalid source position for vertical gradient
Hopefully someone has seen this before and help me get up and going?
