Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3D on Ubuntu 20.04 LTS |
| Print at Aug 26, 2026, 3:44:28 AM | |
| Posted by DerekvG at Oct 28, 2020, 5:00:49 PM |
SH3D on Ubuntu 20.04 LTS I have resinstalled 2 PC's with Ubuntu 20.04 LTS the first thing i installed was SH3D because I want to avoid any issues on My Desktop it works fine. done the same on my laptop and SH3D doesn't start from the terminal it says command not found while i'm in the folder HOW can I diagnose what is going on, what info do you need |
| Posted by DerekvG at Oct 28, 2020, 5:31:06 PM |
Re: SH3D on Ubuntu 20.04 LTS On my laptop installed SH3D as per download page i.e. extracted files to / and maintained the directory structure of the archive - checked permissions for executable and behaviour = run software => doubleclicking Sweethome3D run software starts but the nothing happens => for terminal : cd to SH3D directory then SweetHome3D results in command not found java version : openjdk version "11.0.9" 2020-10-20 OpenJDK Runtime Environment (build 11.0.9+11-Ubuntu-0ubuntu1.20.04) OpenJDK 64-Bit Server VM (build 11.0.9+11-Ubuntu-0ubuntu1.20.04, mixed mode, sharing) |
| Posted by UbuntuBirdy at Oct 28, 2020, 6:46:51 PM |
Re: SH3D on Ubuntu 20.04 LTS What was your exact command to run it from the terminal? You know, you have to start the command with "./"? So the command you have to type in is "./SweetHome3D" (wihtout ""). ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by DerekvG at Oct 28, 2020, 7:40:15 PM |
Re: SH3D on Ubuntu 20.04 LTS indeed that works but Gtk-Message: 19:20:31.218: Failed to load module "canberra-gtk-module" The iconspace in the launcher is empty/blank and it says "com-eteks-sweethome3d-SweetHome3D" starting from Nautilus is still not resolved created a desktop file as |
| Posted by UbuntuBirdy at Oct 28, 2020, 9:51:36 PM |
Re: SH3D on Ubuntu 20.04 LTS Why do you wanna start it from nautilus??? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by DerekvG at Oct 29, 2020, 1:37:44 PM |
Re: SH3D on Ubuntu 20.04 LTS I don't want to start it from terminal because the terminal window stays open. Further more it is not listed in the Application selector I prefer starting it from Nautilus because I know it works, whereas whan I start if from terminal things go wrong and work gets lost. ( I have been working like that since feb/march of this year whan I reinstalled and had the same problem and instability over and over again. Moreover I can save the launcher instance to luncher favourites and i can restart it from the launcher bar The Bundle in the distro is out of date 5.x( if i'm not mistaken) it's not even worth to install BTW ============= on my last start in Terminal following errors showed up ... ~/SweetHome3D-6.4.2$ ./SweetHome3D Gtk-Message: 11:28:55.194: Failed to load module "canberra-gtk-module" Exception in thread "pool-8-thread-1" java.lang.NullPointerException at com.eteks.sweethome3d.swing.ImportedTextureWizardStepsPanel$19.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) |
| Posted by DerekvG at Oct 29, 2020, 1:56:20 PM |
Re: SH3D on Ubuntu 20.04 LTS this is my .desktop file (on both machines disk config, mount points and directory structure are identical) [Desktop Entry] Version=1.0 Name=Sweet Home 3D 6.4.2 GenericName=Interior 2D design application with 3D preview GenericName[de]=Innenraumplaner Comment=Interior design Java application for quickly choosing and placing furniture on a house 2D plan drawn by the end-user with a 3D preview Exec=/home/derek/SweetHome3D-6.4.2/SweetHome3D Icon=SweetHome3DIcon StartupNotify=true StartupWMClass=com-eteks-sweethome3d-SweetHome3D Terminal=false Type=Application Categories=Graphics;2DGraphics;3DGraphics; Keywords=interior;design;2D;3D;home;house;furniture;java; |
| Posted by UbuntuBirdy at Oct 29, 2020, 5:12:21 PM |
Re: SH3D on Ubuntu 20.04 LTS Not sure if it helps, but try to edit the "Path" and the "Exec" line in your .desktop file like this: Path=/home/derek/SweetHome3D-6.4.2 Exec="/home/derek/SweetHome3D-6.4.2/SweetHome3D" %U And then save this .desktop file in "/home/derek/.local/share/applications" SweetHome3D will now appear in your applications. You're right, starting from the terminal is not an acceptable option. But you could even start a software from the terminal with a .desktop with the corect exec line. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by DerekvG at Oct 29, 2020, 10:24:25 PM |
Re: SH3D on Ubuntu 20.04 LTS Got it to work from Nautilus I edited the .desktop in /usr/share/applications and corrected the path to /home/derek (replaced the capitals) I changed the properties of the file , and in permissions switched off the executable flag and open with text editor. In Nautilus : Preferences -> Behavior -> Executable Text Files to Ask what to do. Stopped Nautilus , and rebooted Ubuntu , started Nautilus In Nautilus : Preferences -> Behavior -> Executable Text Files to Run executable. I changed the properties of the file , and switched ON the executable flag of SweetHome3D and open with Run software. and it starts and i could append it to favorites (dock) |
| Posted by UbuntuBirdy at Oct 29, 2020, 11:10:21 PM |
Re: SH3D on Ubuntu 20.04 LTS WOW! I tried to help you, and now you showed me how to do it! NICE! Next time you do not have to reboot Ubuntu, you only quit Nautilus from the terminal with "nautilus -q". And then start Nautilus from where you do it normally. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by DerekvG at Oct 30, 2020, 12:57:52 AM |
Re: SH3D on Ubuntu 20.04 LTS You helped me, very much, but i think it's good practise to give feedback when it's solved, so when people read the issue they may get an idea how to solve it In this case yout comments showed i needed to look elsewhere for the problem |
| Posted by UbuntuBirdy at Oct 30, 2020, 10:41:34 AM |
Re: SH3D on Ubuntu 20.04 LTS Yes, I agree! It's absolutely important, that you tell us not only that your issue is solved, but how you have solved it! Thanks for that! ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by TechnoTarzan at May 31, 2024, 9:15:14 PM |
Re: SH3D on Ubuntu 20.04 LTS Hola! I am jumping into this thread because I have a similar problem, but being somewhat of a n00b to Ubuntu, I am having difficulty following along. I am running 24.04 LTS 64-bit on Gnome 46 with Wayland. If you need more details just ask.... My problem is similar when I launch the icon from Nautilus, I right click and Run and it launches the SH3D-7.4 but terminal displays: ~/Downloads/SweetHome3D-7.4$ ./SweetHome3D Gtk-Message: 11:49:42.052: Failed to load module "appmenu-gtk-module" Gtk-Message: 11:49:42.057: Failed to load module "canberra-gtk-module" Any advice is appreciated. Thanks for your work on this app! Going to layout a small house for my daughter. |
| Posted by TechnoTarzan at Jun 1, 2024, 9:27:51 PM |
Re: SH3D on Ubuntu 20.04 LTS UPDATE: I was able to remove teh errors above by using these: sudo apt-get install libcanberra-gtk-module sudo ln -s /usr/lib/x86_64-linux-gnu/gtk-2.0/modules/libcanberra-gtk-module.so /usr/lib/libcanberra-gtk-module.so sudo apt install appmenu-gtk2-module sudo apt install appmenu-gtk3-module When I execute the icon in the SH3D folder, it executes but terminal still loads and the instant I click on FILE to start any task, I get this message: ** (java:81951): WARNING **: 12:25:31.677: Invalid borders specified for theme pixmap: /usr/share/themes/Breeze/gtk-2.0/../assets/line-h.png, borders don't fit within the image ** (java:81951): WARNING **: 12:25:31.677: invalid source position for vertical gradient ** (java:81951): WARNING **: 12:25:31.677: invalid source position for vertical gradient ** (java:81951): WARNING **: 12:25:31.678: invalid source position for vertical gradient ** (java:81951): WARNING **: 12:25:31.678: invalid source position for vertical gradient Hopefully someone has seen this before and help me get up and going? |
Current timezone is GMT Aug 26, 2026, 3:44:28 AM |
