Print at Aug 25, 2026, 4:50:21 AM View all posts in this thread on one page
Posted by manishlulla at Jul 2, 2020, 2:20:58 PM
Trapezoid Window
Hi All Power Users,
I am trying to find how to put trapezoid windows in my model. Need to be able to change the dimensions as each window is a different size.
Thank you very much in advance.
Manish
https://www.pinterest.com/pin/201958983016206...db2jw4cxXTM4HZziSxvjWrFzb[/img]
Posted by Mike53 at Jul 2, 2020, 3:00:32 PM
Re: Trapezoid Window
Whether you have made them yourself or downloaded them from elsewhere, during the import process you need to select (checkbox) that the object will be a door or window, once you have done that it should fit correctly into the wall and still enable you to modify the dimensions
Posted by manishlulla at Jul 2, 2020, 3:18:01 PM
Hi Mike,
Thank you.
I am a newbie, didnt follow your note.
I want to create a trapezoid window, I cant find a trapezoid window object for SweetHome3D. All windows are square. Thank you.
Posted by VeroniQ at Jul 2, 2020, 3:36:13 PM
There were some special windows in this article. Maybe they could feet...
Posted by manishlulla at Jul 2, 2020, 6:26:17 PM
Excellent, Thank you very much!
Will try these out.
