Print at Sep 21, 2026, 6:12:16 PM
Posted by KitchM at Jun 19, 2020, 10:05:34 PM
Convert Polyline to Wall
Can the user change a polyline into a wall?
Posted by Mike53 at Jun 19, 2020, 10:25:01 PM
Re: Convert Polyline to Wall
I do not believe, so but you could draw your wall over the polyline
Posted by KitchM at Jun 19, 2020, 10:52:27 PM
Okay. Thanks. I was afraid of that. I'm trying to build a greenhouse that is buried 4 feet into the ground. There are no walls in the ground so I thought the lines would be good enough. The walls above ground are outside that area. I wanted to see a multilevel design, but I couldn't see the below ground part in the 3D view anyway. Maybe it only shows up if the lines are actual walls.
(I'm wondering if I should do everything in one view instead.)
