Previous Thread This topic has been viewed 2903 times and has 2 replies Next Thread
KitchM
Convert Polyline to Wall
Can the user change a polyline into a wall?
[Jun 19, 2020, 10:05:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Convert Polyline to Wall
I do not believe, so but you could draw your wall over the polyline
[Jun 19, 2020, 10:25:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
KitchM
Okay. Thanks. I was afraid of that. I'm trying to build a greenhouse that is buried 4 feet into the ground. There are no walls in the ground so I thought the lines would be good enough. The walls above ground are outside that area. I wanted to see a multilevel design, but I couldn't see the below ground part in the 3D view anyway. Maybe it only shows up if the lines are actual walls.
(I'm wondering if I should do everything in one view instead.)
[Jun 19, 2020, 10:52:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
