Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to make the color and shape look the same |
| Print at Aug 20, 2026, 11:53:24 AM | |
| Posted by Bill_L at Jun 8, 2020, 5:56:29 PM |
How to make the color and shape look the same Hi, everyone, I am trying to use the software to create a set of pictures for my visual search experiment. I want the distractors to have the same shape but different color or have the same color but different shape as the target. For the shape, I don't need the same shape/different color to be exactly the same shape, I only need it to look the same size as the target. But due to the distance and lighting, I can't have the same shape or same color unless I use my owe eye to adjust it. I attach a picture to illustrate, the tablet in the red rectangular is the target and the two frames in the black are the distractors. Any suggestions about how I canget the same shape/color in a more systematic way, so I don't have to writhe "use my own eye" in my paper? Thanks in advance. ![]() |
| Posted by Puybaret at Jun 10, 2020, 9:06:17 PM |
Re: How to make the color and shape look the same If you don’t want that the lights of the scene alters the color of an object, you could use a 3D model at OBJ format with an associated MTL file containing materials with an illum 0 setting. See this thread for some examples (even if that thread is about how to make glowing lights with ray tracing renderers). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Jun 10, 2020, 9:19:13 PM |
Re: How to make the color and shape look the same And about the fixed shapes, it’s not possible to avoid the resizing / deforming / hiding effect of the perspective projection. Using OBJ spheres with an illum 0 setting could avoid the deforming effect (you would get a disc with a fixed color) but it still could be more or less large at screen according to its distance to the camera and possibly hidden by other objects in front of it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Bill_L at Jun 12, 2020, 5:45:12 PM |
Re: How to make the color and shape look the same Thank you. I will try to use the .obj format |
Current timezone is GMT Aug 20, 2026, 11:53:24 AM |
