Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: I need a little help! |
| Print at Aug 20, 2026, 10:08:07 AM | |
| Posted by oldies2000 at Jun 5, 2020, 3:57:30 PM |
I need a little help! Hello, everyone, I would like to make a round room cutout of 180 cm on the first floor, so that one can see a sculpture in the basement. Can someone please help me in a friendly manner? Thanks! |
| Posted by Nauthiz at Jun 5, 2020, 6:05:09 PM |
Re: I need a little help! The metod is similar as shown in this tip, but for cutting floors you need a dummy element imported as a staircase, not door or window. I've just uploaded a file with two elements like this I'd made for myself - see here. This is a library file, so import it as library and you'll find a cutting cylinder and a cutting cube in a folder named "construction". Put the cylinder in the basement and elevate it so it goes through the ceiling, then you should see a hole on the first floor. Resize the cylinder and modify the material to invisible. |
| Posted by oldies2000 at Jun 7, 2020, 1:36:13 PM |
Re: I need a little help! Thanks for the support, everything worked out fine! Best regards from Germany |
Current timezone is GMT Aug 20, 2026, 10:08:07 AM |
