Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: 2 floor restaurant. » » » » Post: Re: 2 floor restaurant. |
Print at Sep 20, 2026, 2:51:20 PM |
| Posted by hansmex at Dec 29, 2010, 8:47:07 AM |
Re: 2 floor restaurant. Fred, When there is a link in a message, it is a good idea to follow it to see what information it points to. Check out the earlier messages... I gave a link to "How to share images and files" ! It explains how to easily share files, even when 100Mb or larger. If you only read half of the messages we post, it's a waste of time. When you want to use the plug-in CopyAsNewFurniture do it exactly <!!> this way: - Open the source file from where you want to copy - Open the target file to which you want to copy - In the source file, select the part of your design that you want to copy with the mouse - In the source file, click Tools --> Copy as new furniture - Switch to the target file and do a Right-click and Paste - Move the copied block into position and give it the correct elevation Note - There is no need to group furniture! Note - it is imperative that both instances of SH3D are open before you start the copy action! This is the way I made the restaurant above. It works, as you can see. Since you write that you created a .eteks directory, I assume you are using Linux/Ubuntu, just like me. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 2:51:20 PM |
