Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Use all screen realstate in scrolling window manager » » » » Post: Re: Use all screen realstate in scrolling window manager |
Print at Sep 15, 2026, 5:58:43 AM |
| Posted by Daniels118 at Mar 12, 2026, 6:05:43 AM |
Re: Use all screen realstate in scrolling window manager The program fails to calculate the real size available, most likely because it fails to recognize the dpi, perhaps on a high dpi display. There is a custom setting which allows to override the default scaling, see this post and experiment different values until you get the expected result: https://www.sweethome3d.com/support/forum/vie...read,5384_offset,10#28822 If it doesn't work at all, you may try to reduce the dpi to a standard value. MS WINDOWS allows to force the dpi to a specific value when a target program is executing (compatibility option), perhaps you can achieve the same on Linux (using some additional software?). |
Current timezone is GMT Sep 15, 2026, 5:58:43 AM |
