Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Question concernant le plug-in générateur de toit » » » » Post: Re: Question concernant le plug-in générateur de toit |
Print at Oct 5, 2026, 8:53:02 PM |
| Posted by dorin at Feb 9, 2026, 4:38:53 PM |
Re: Question concernant le plug-in générateur de toit 1. Your approach is more complicated. You tried to create a single room with a hole. In the tutorial and in my demo file, there are several rooms. One large room and one or more smaller rooms, representing the holes (inner courtyards). You must select all these rooms and run Generate Roof. 2. After positioning the roof window from the library (X and Y positions only), you must choose the appropriate roof and regenerate it. The plugin will take care of the rest. 3. It appears that you have discovered an bug: when the roof slope is greater than 45 degrees, the roof window does not lift properly. Now it must be adjusted manually. I need to look into this further and will try to resolve it. Thank you! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 5, 2026, 8:53:02 PM |
