Print at Sep 20, 2026, 10:35:21 PM
Posted by GaudiGalopin3324 at Jan 27, 2026, 11:53:43 AM
Re: How to add skirting boards?
hi. There are several ways to add a baseboard in the program. One of them is to make a skirting board in the form of a thin long box, for example, 7cm high and 1.5 cm thick. You need to assign a texture or color to all visible sides. Enable the Magnet option and glue these baseboard boxes to the walls. The inner corners turn out by themselves, and the outer outer corners need to be carefully connected and aligned. And the main method is embedded in the program itself, look in the wall or floor settings, I don't remember. There's a very normal skirting board.
