Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: My Custom Textures Stretching? » » » » Post: Re: My Custom Textures Stretching? |
Print at Oct 5, 2026, 8:21:11 PM |
| Posted by Keet at Dec 10, 2025, 9:29:47 AM |
Re: My Custom Textures Stretching? I made a simple 6 sided rectangular shape using exact dimensions of one of my guitar amps. Did you use a box and resize it to the required dimensions? Although it should have worked it's possible that textures do stretch.Try the ShapeGenerator plugin. It adds a menu item Generate 3D Shape under the Tools menu. With it you can create your box with the exact dimension without having to stretch the default dimensions. Texturing should fit better now. If that still doesn't work you can use Blender to fix it but that requires a little knowledge of Blender. I can explain it if you want to try that. There is a big advantage if you can use Blender for this. For example you can create a guitar shape using walls and/or rooms and then use Blender to fix the front faces so you can put an image of the guitar on it. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 8:21:11 PM |
