Print at Sep 20, 2026, 7:11:22 AM
Posted by Keet at Nov 15, 2025, 4:54:35 PM
Re: Light Problem
You can only see the light when you generate a photo, not in the 3D view.
You can set the light power when you modify the light (Modify furniture): at the bottom right you will see a setting "Light power" with a default value of 50%. In most cases that is way too much, often 5-10% is more than enough.
