Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Split Wall, how to separate the two ends » » » » Post: Re: Split Wall, how to separate the two ends |
Print at Sep 9, 2026, 9:53:26 PM |
| Posted by dorin at Oct 2, 2025, 7:11:11 PM |
Re: Split Wall, how to separate the two ends 1. I use the same method when I need a single wall in place of a splinted wall. 2. Not one but two: -one in the default program: Plan->Join Walls (Ctrl+Alt+J) -second (if you have installed Advanced editing plugin): Plan->Connect walls. Both need to have at least 2 walls selected. Look similar but each have also some different results. Generally will connect the end of the first selected wall with the start of the second. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 9, 2026, 9:53:26 PM |
