Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: 2D view » » » » Post: Re: 2D view |
Print at Sep 22, 2026, 2:05:59 AM |
| Posted by Keet at Jan 6, 2025, 3:09:46 PM |
Re: 2D view Yeah, that's how I started making in through. The repository has an old version. Download the latest version from the download page . Extract the .tgz file where you want and create a launcher with the SweetHome3D-Java3D-1_5_2 script. If needed you can add the ulimit command in that script.Should I then uninstall SH3D from the repositories? Or does it come with Java3D script too? There is a SweetHome3DIcon.png in the extracted directory where the script is that you can use as the launcher icon. When a new version appears simply download and extract in a new directory. That way you can have multiple versions to test the latest version without losing your previous install. Ignore the install from the repository. You might want to add these to the java command in the script: -Duser.name=username which uses 'username' when you create a furniture library and sets it as the designer name in .sh3d project files. If you don't, the machine username is used which you probably don't want to show if you share files. -Xmx6g sets a higher limit to the amount of memory Sweet Home 3D can use. Read more about it on FAQ page (heading "How can I adjust the memory used by Sweet Home 3D?") My java command starts like this: "exec "$PROGRAM_DIR"/runtime/bin/java -Duser.name=Keet -Xmx12g ..." Notice that the java version supplied in the downoad is used. Make sure you install the Plugins Manager plugin. Using that plugin it's very easy to install and update other plugins. A must-have plugin is the AdvancedEdit plugin, you can check the other available plugins in the list and install them with a few clicks. edit:typos ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 22, 2026, 2:05:59 AM |
