Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Distribute elevation plugin » » » » Post: Re: Distribute elevation plugin |
Print at Sep 6, 2026, 5:28:13 AM |
| Posted by dorin at Apr 5, 2024, 8:11:14 PM |
Re: Distribute elevation plugin New version 1.1 Reminder: This plugin distribute selected furniture at equal elevation interval. You will find it under Furniture (or corresponding translation) menu and an icon on the tools bar. News in this version: 1. For users: -add the possibility to work inside furniture groups. That mean if you modify the elevation in a group of furniture (eventually generated with Multiplier plugin) and select this group, this plugin will modify the pieces elevation inside the group. The minimum of 3 pieces number remains as mandatory. -add Italian, German and Chinese translations (DeepL translator). 2. For developers and translators: Now if you switch the language the plugin will be translated without need to restart the application (thanks to Emmanuel). I've added pre-made files for all localization present in SH3D (18 files). A potentially translator (who want to modify or to make a new one) will find them under locales folder inside the plugin, initially in English. Their name looks like this: pkgDE_de.properties for German. What that means? -pkgDE=pkg+DE (DE=acronym for Distribute Elevation) -_de= the localization indicator (German in this case) -.properties= the file extension I intend to do this to all my plugins but with their specific acronym (or closer): SHU= Select Hide Utility RR= Regular Room GR= Generate Roof and so on. So, a translator could send me multiple files with the translation for different plugins at once. I also intend to use it as a template for all my plugins. I'm still thinking about it wile is not as good as I wish. That's all! Also on Source Forge ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 6, 2026, 5:28:13 AM |
