Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D pictures rendering problem » » » » Post: Re: 3D pictures rendering problem |
Print at Sep 28, 2026, 2:34:53 AM |
| Posted by hansmex at Jan 11, 2023, 7:28:58 AM |
Re: 3D pictures rendering problem Your model renders without problems on my PC. Tips to render: - in the Furniture List make visible the column Model Size. - sort that column - make the 6 largest models invisible - this reduces the file size with 140-150 MB - read the FAQ where it says: Under Windows, create a text file named SweetHome3D.l4j.ini in the same folder as SweetHome3D.exe, write the maximum memory Java option in that file, for example -Xmx700m for 700 MB, then relaunch Sweet Home 3D. For a value higher than 700 MB, tested as the highest value under which Sweet Home 3D can run safely on a 32-bit Windows computer with little RAM, you should use a computer running 64-bit Windows and install Sweet Home 3D 4.3 or higher. - allow SH3D as much memory as possibleH ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 28, 2026, 2:34:53 AM |
