Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: I need a little help! » » » » Post: Re: I need a little help! |
Print at Aug 20, 2026, 9:23:39 AM |
| Posted by Nauthiz at Jun 5, 2020, 6:05:09 PM |
Re: I need a little help! The metod is similar as shown in this tip, but for cutting floors you need a dummy element imported as a staircase, not door or window. I've just uploaded a file with two elements like this I'd made for myself - see here. This is a library file, so import it as library and you'll find a cutting cylinder and a cutting cube in a folder named "construction". Put the cylinder in the basement and elevate it so it goes through the ceiling, then you should see a hole on the first floor. Resize the cylinder and modify the material to invisible. |
Current timezone is GMT Aug 20, 2026, 9:23:39 AM |
