Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Multiple paste & Distribute elevation plug-in » » » » Post: Re: Multiple paste & Distribute elevation plug-in |
Print at Jul 21, 2026, 11:00:52 PM |
| Posted by dorin at Jun 9, 2019, 3:23:13 PM |
Re: Multiple paste & Distribute elevation plug-in @VeroniQ I'm happy You find it useful. I forget to mention: is localized in french (google help). Use with caution!! You could insert hundred pieces at once but then, if something You don't like it, You will have to make hundred undo (Ctrl+Z). Don't forget this is a controlled paste (Ctrl+V) so will have all the original paste characteristics with good & bad. Keep in mind two things: 1. After You select and copy (Ctrl+C)- deselect it or select other object to activate the plugin (at least on first use). 2. The number of paste NOT include the original object(s). ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Jul 21, 2026, 11:00:52 PM |
