Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: transparent vertical and horizontal glass square » » » » Post: Re: transparent vertical and horizontal glass square |
Print at Sep 20, 2026, 1:48:34 AM |
| Posted by Gildaniel at Apr 29, 2019, 12:59:29 PM |
Re: transparent vertical and horizontal glass square Without seeing the shape of your roof its hard to be certain, but it does sound like you need to use a wall, set its width and height to suit, then position ANY window with the dimensions matching your velux, export > import, set its angle, make the window invisible and then position your velux. You may need a couple of attempts at the wall height as this shortens as you angle it. Good Luck Mike It's a great idea! We can use "Copy as new furniture" tool instead of import/export (http://www.sweethome3d.com/support/forum/viewthread_thread,1331_offset,11) So: 1. Draw wall and put window in it 2. "Copy as new furniture" and paste, now we have vertical roof with window 3. "Change furniture" -> rotate around X or Y to ajust needed angle Now I thing it would be more easy to make roofs not from boxes and triangles, but from walls. Trianle hole for complex roof forms is here http://www.sweethome3d.com/blog/2014/10/09/ho...the_bottom_of_a_wall.html If you need equilateral triangle just put two of them near, one mirrored |
Current timezone is GMT Sep 20, 2026, 1:48:34 AM |
